Any chance you have more pictures of this setup from the side and front to see how far the wheels stick out? Looks great!
This is the exact same setup.
LOL, but not a 365/20R20 as posted......
I just didn't want someone to go looking for them for their TRX,.,,, (y)
Yeah I know…. Just messin. Long standing joke with Jeep crowd that BFG’s are some of the smallest tires in relation to the advertised size. 😎
Yeah, I had them on my old Gen 1 Raptor years back. 37’s were maybe 36.5” if lucky, which helped with clearance. Also, they’re on the “lighter” side when compared to other options. The perfect commuter tire if you mostly stay on asphalt, with great road manners & wet/dry traction & very little, if any, noise. There’s definitely better options for off-roading, but these are IMO the perfect commuter tire with some decent off-road capability. They’re a step under the hybrid M/T-A/T (Toyo R/Ts & Nitto Ridgegrapplers).
This is the same setup @Boosted has with a BFG tire. I don't think they are as wide as the Nitto but I do think the Nitto looks meaner. I decided to give the BFG tire a try since I have never run them before. The are smooth and as quiet as stock. If I remember right, I think I only picked up 3 pounds per wheel and tire with the upgrade. The weld wheels are light.
Love it, I am going to follow suit and do this exact set-up on my truck.
Weld 20x10 -16
BFG or Nitto 325/60/20
I wasnt able to figure it out, Do you or Boosted have a front end levelling kit installed? Forgive my ignorance if I missed it in the thread.
Weld 20x10 -16
The wheels are 20x10 with -18 offset. Not big difference other than you won't find any with -16. :cool:
My truck has the Rogue Offroad level kit installed with just the lower perches.
Thanks. I'm very pleased with how they turned out. No rub so far on street driving, including trying to get them to rub coming in and out of parking lots. The fenders didn't blow off either when I hit some rail road tracks at 60mph and got a little airborne.
It's a tight fit though.
Wow that IS a tight fit! But it looks excellent, especially with those bronze wheels. So if you’ve had no rubbing running those with stock suspension, I obviously must be safe to run the same size after tire/wheel after I’ve added a levelling kit to the front, would you agree? I want the levelling kit to improve the appearance and to let me run 37s with a bit of leeway..Thx, dave
37x13.50r20 Nitto Tires
20 inch Covert Fuel Rims with a 20 offset
awesome truck, do these fit with no levelling or no lift at all? I’m thinking of getting my stock TRX levelled this Wednesday under the impression that it will make the truck look “better” if it sits level and possibly upsize my wherld and tires at a later date. But I’m questioning myself if there’s really any benefit for adding a levelling kit, especially if I could fit 37s in the future with totally stock height…
Here’s my TRX in Hawaii
I went with Black Rhino wheels -18 offset and Yokohama Geolander X-AT 325/60R20
I like these wheels because they are 35.5 in diameter so 1” bigger the 35s at 34.5
I like the ratio, looks proportioned to me
They do rub on drivers side only and when i turn hard left and hit a bump
I can probably trim the plastic and get away with it. But considering a leveling kit
Still have stock wheels and tires
Took Ram bar off. May put it back on. Took tire carrier off. Going to do tonneau cover. And mopar retractable steps
Looks excellent bro👍🏻
