Easiest way is to use the included USB reader if you want to move multiple files from the dash cam to your computer. The app works for me without having to shut off bluetooth or manually disconnect it from Carplay but YMMV I guess.
The bottom line is I have it in case of an emergency. If I get hit I'm covered. The only thing I don't understand is the settings for impacts. Which it the correct one?
How bout normal/medium. either that or set it to low and go run thru a wall & let us know if it works
I left it on the default and I can see it's locking files when I hit larger pot holes and such so it's working as intended.
Is anyone else having an issue fitting the new housings back flush to the widnshield? Mine has a noticeable gap (where it touches the windshield) that wasn't there before. It's hard to see in the picture, but it is flush at the bottom and the gap grows to 1/8"+ at the top.
My gap is exactly the same as the stock unit. I did have a bigger gap than original when it wasn't fully seated. You may want to pull it off and ensure it is fully clipped into all 4 posts.
Yeah, I pulled it off a couple of times and made sure no wires were pinching or anything. It was almost dark, and I couldn't see things too well. It sure felt like the housing was solidly pressed up/in as far as it would go.
I guess I'll have to pull it off one more time and have a good look at where it's making premature contact at the top.
I had an issue with mine where it wouldn't fully seat due to the power wire being too tight up against something else. I had to physically move that wire onto the other side of the mirror mount because if I pushed too hard to try to get it to seat more fully onto the clips, it would literally dislodge the mirror off the mount of the truck. It took a few times for me to get it just right. There isn't as much room behind there as there appears to be.
Just installed the front & rear cameras. I have created several sample files but can’t complete a download of any to my iPhone 11. The download fails at 5% due to the network dropping while sitting in the driver seat. I tried both the FITCAMX and Viidure apps with cell service turned off. Anyone else with this issue?
Yeah, no luck installing mine so far.
I didn't try downloading a video file from the app, but I noticed mine kept disconnecting from the fitcamx and reconnecting to the truck's wifi. Maybe try turning off the truck's wifi and see if you can keep the connection?
For anyone who bought one of these and doesn't wanna fit it - I may be willing to buy it
Finally got it after disconnecting phone. Whole thing is wonky for app use :)
Pretty sure mine is just like that.
Installed mine over the weekend. Easy install and your video was very informative. Downloaded both apps, but for know the FitCamx app seams to be working just fine.
Thank you for the find and the added sense of protection.
