OK, I've posted about this a couple of times, but I have now ordered one and tried it. It seems to work very well. I replaced one of the starter relays, and the truck will not start even with the "key" unless I arm the Mobilistics relay with the wireless fob. The only way I know it could easily be beaten is if the thieves know how to hotwire the starter, but from other posts I've seen it appears they mostly use software to program a new "key" which they use to start the vehicle. This relay would prevent that from working. Maybe y'all can think of another way to defeat it, but other than actually opening up the fuse box and replacing the relay, I cannot.
A drawback is it is necessary to use two fobs to start the truck now, if you consider that much of a hassle. The pluses are it seems to me effective, it costs less than $100, and it doesn't require any wiring modifications, hidden switches, or specially mounted devices. The remote start even works, but you have to be close enough to the truck for the relay to read the Mobilistics fob, which appears to be right beside it.
If anyone is interested, the part number to order is SRI-MG and the website is:
https://www.mobilistics.com/nostart...relay-w-remote-starter-fuel-pump-immobilizer/
I have mentioned before but in case anybody is wondering, I am not associated with the product in any way. I just want to recommend something I found that seems to be a good solution to a lot of worries.
