AlfaOBD Tips and Tricks
I have read through this post a couple times but I just want to confirm. I have a 2023.
-Can I use the older OBDLink MX Bluetooth?
-Can I use the OBD cable adapter mentioned in 1st post or the ECRI Security Gateway Module Bypass or do I need both?
-Yes I will need AlfaOBD app, which I have Android
I want to do this:
-Amber DRL
-Add the Mopar Power Running Boards to Uconnect so I have a button to keep them out or folded
Once I enable the 2 things I want to do, I can disconnect everything? Nothing needs to stay connected?
Thanks!!
I want to do this:
-Amber DRL
Thanks!!
I'm not sure what the OP was referencing in his first post, but most SGW bypass cables or the ECRI unit will do the job. Your OBDLink should be fine for what you are trying to change.
Nothing needs to stay connected. I remove the SGW bypass and OBD link after every change.
Thank you!
I already have the OBDLink MX Bluetooth so it won't hurt to try. If it does not work I will pick up vLinker
You’ll be good. MX+ always works perfect for me and the only difference between the MX and MX+ is iOS support. Not relevant to AlfaOBD.
As an aside, the MX/MX+ are actually some of the better options to have because they can also get onto the IHS bus without need for an adapter cable. Just in case you ever need to troubleshoot the radio, HVAC or many other various modules throughout the truck.
Does anyone have an alpha obd backup confile they can share with me by chance ?
Thanks in advance for any help !
Cheers
Has anyone turned off the seatbelt chime in a 23 with the alfaobd? Doesn't bother me, but a friend really wants to turn it off.
I stumbled onto a solution to disable the seatbelt chime on the 23's using Jscan, on the 5th Gen Ram Forum. Connect as a 1500 DT for the vehicle >Adaptation > Vehicle User Settings > Seat Belt Alert On/Off. Hopefully @Jimmy07 figures out a similar setting using AlfaOBD. If not, I'm going to purchase Jscan, just to disable the chime.
Reactions: Two
You can disable it with Alpha.
You got to connect to 23 instrument cluster and go to program custom features and turn of seat belt alert .
I did this two weeks ago and works well .
Well, damn. I just tried on mine a few weeks ago too, and I always got the parameters not correct message, same as the other 5th gen clusters. I ended up using witech to disable it last week when I had a subscription.
Is this the setting on AlfaOBD?
Let us know if it works .
Seems like it might be a hit or miss .
I got it to work first try on a 23 dt rebel .
I am using the windows version
With the new digital cluster .
I got it work first try on a 23 dt rebel .
Just realized, that’s my fault, I’m way behind on my android version updates, and it’s not set to automatically update. I didn’t even have MY2023 listed on the version I was on.
