AlfaOBD Tips and Tricks
Yes. The change is represented in my photos.
4.4c is the original setting. I changed it to 4, procedure complete, click start again, and “option set currently as: 4° c”
I see that you are using the windows version of AlfaOBD. I am using Android, the latest version of AlfaOBD, 2.4.0, and the OBDLinkMX+. Sooo...I got home and rushed out to try this. It did not work for me. I will try to get some screenshots up later. I also tried the OBDLinkEX via USB. I have tried two different Android devices. No luck.
Does it go through 4 can attempts then fail to connect?
Yes and got the error below :(
Will go through Jimmy's instructions again now.
You’re connected to the wrong module.
Got it, will try again, Thanks Jimmy.
While we are on the subject of comfort, is there a way to get the seat vent to start at the highest speed (3) rather then the lowest (1)?
Yes, using the Android version. As far as I can tell the Android version will not connect to the Comfort module.
I went out and got he Windows version and now I have had a lot of success changing the temperatures and some other things within the Comfort module. I still get some odd results, though. For example, I was able to raise the temperature for heat activation, but I can't decrease the temperature for vent operation. AlfaOBD sometimes says the operation is complete, but when I later look there is a random number for the setting; right now the seat vent is activated at -29.72C and I cannot change it. I have tried changing some of the ramp and steady state temperatures...and that is, again, a total crapshoot. If I get a "Procedure Completed" message there are random numbers in the fields. If I do not get the procedure completed message then there can be an error message.
I'm open to suggestions!
Hope you can share this! I cant wait to fix this annoying chime
Here it is, connect to the instrument cluster, Seatbelt Alert system =Disabled.
Cannot connect to Comfort.
What are the ramp and steady state?
Probably just conversion errors when he put these settings in. I can correctly change all of that stuff with cda.
Hmmm. Quite frustrating. There mus be something simple that I am getting wrong. Here is today's error message:
what are options are there for reading from the ECM/BCM directly?
Via Android? I have both Windows and Android, but I have very limited experience with the Windows app.
