I tried the newer dual, found to be two variants with late 24's and early 25's using charger modules without fans and the rubber bezel more or less the same as previous years then sometime in 25 it changed to a thin rubber with perforations and chargers with fans. This has been my experience when buying g/t, trx and a limited console from 24 and 25's. I couldn't get them to turn on so I modded the whole bezel and installed magsafe in their place for an oem look.
I have the non-fan versions and rho console harness with the module if you need help with testing.
Also for the 25/26 console with hdmi and pass usb I found splicing into the panel lamps ambient light circuit on the 19-24 wiring powers both and more interestingly is in my research the pass usb just runs off that circuit so just charges, thought it would had data too but unless in the 25/26 where the console wiring for everything routes in and out of the module in the rear suppose that's the design to only charge.
19-24 on left. 24-25 on right non fan early 25 model years. Non interchangeable, wire harness plugs fit and wires align, but do not function nor physically fit between bezels.
25-26 latest duals with fans, interchangeable with the non-fans in late 24 early 25's.
