Featured
- #661
Check eBay, there was a couple that popped up over the weekend I seen while browsingDoes anyone have a digital cluster they’re selling or any leads to where I can get one besides the dealer?
Do you have any links? I’ve been looking the past few days and haven’t seen a single oneCheck eBay, there was a couple that popped up over the weekend I seen while browsing
The TRX’s don’t have that problem when doing the digital cluster swap.Has anyone else experienced that the prnd changes are not showing in the 2020 ram 1500 digital cluster
Do we still need the bypass cable installed for the maps on the cluster?Just leaving a recap on the alfaobd settings here as a reference, since I get a lot of PMs referencing this thread for the swap with questions on manipulating the backup file:
Editing the raw hex in the backup file is no longer necessary. The relevant settings have since been added to the standard car configuration change list.
These are the settings to change after the full swap:
VehConfig 1: Model Year- 2023
ECUConfig 3: Audio Steering Wheel Switch Configuration- Core Steering Wheel
ECUConfig 3: Unique Core Steering Wheel- Yes
CustSetMenu 3: Album Art In Cluster- Yes
CustSetMenu 3: Audio Steering Wheel Controls on IPC- Yes
CustSetMenu 3: Cluster Size- 12 Inch
CustSetMenu 3: Nav Map In Cluster- Yes
Bonus Feature for those equipped with front park assist and surround view cameras:
CustSetMenu 3: Park Sense Based Camera Activation- Yes
In case you gained rear seat alert reminder with the 2023 BCM swap, these will get rid of all chimes and warnings associated with it:
CustSetMenu 3: FOA Type CSO- No
CustSetMenu 3: FOA Presence CSO- No
In case you gained the “three horn honk” with the 2023 bcm swap:
CustSetMenu 3: Unintended Idle Alert- No
yesDo we still need the bypass cable installed for the maps on the cluster?
Updated the main post with that, thanksJust leaving a recap on the alfaobd settings here as a reference, since I get a lot of PMs referencing this thread for the swap with questions on manipulating the backup file:
Yeah, I believe it’s an issue with the older SGW module, so you either need to leave it bypassed, or install a 2023+ SGW module.
I’m sure @OnTheReel would be willing to step up and try this out.Yeah, I believe it’s an issue with the older SGW module, so you either need to leave it bypassed, or install a 2023+ SGW module.
I’m not sure. I usually completely remove SGW’s and configure them out of the BCM. I’ve never purposely tried installing a new one.I’m sure @OnTheReel would be willing to step up and try this out.Is swapping in a 23 SGW module something that can be done at home or does it involve the dealer service department?
It should be a little cheaper with the CAN module vs the BCM swap, and without the headache of a dealer visit.Do you guys see any interest for a can module versus a new bcm ?
The cost will probably be similar is my guess but how much is a new bcm for the DT?
I got maps working on my 18 truck with a can module to send the missing data .
don’t remember the cost of the bcm, but the cost of the BCM plus the cost of the install could make a can module a decent amount cheaper.Do you guys see any interest for a can module versus a new bcm ?
sounds about right.. Probably 250 ish for the bcm and 150 ish for the installI don’t keep track of costs with this truck because it’s too depressing. But wanna say I’m into the BCM for at least $400 with install. And it was a pain in the ass too.
Ok thanks for the feedback .I don’t keep track of costs with this truck because it’s too depressing. But wanna say I’m into the BCM for at least $400 with install. And it was a pain in the ass too.
in my mind Not having to do a dealer visit to have something installed in your truck that was not supposed in your truck is a big selling factor. I was very worried about doing the bcm swap. It worked out but there was a cost associated, there was stress associated, and just the time. To pay less to avoid that would be great.Ok thanks for the feedback .
I will work on this over the next few weeks .
Just want to finalize the HD trucks module .
