Vossen 20” wheels
BFG A/T tires 325/60/20
Apparently they just clearanced the caliper of the stock brakes. I imagine it took a lot of clearancing though since some 18" cast wheels won't even fit. I haven't looked to see how much material is on those calipers that you can actually grind off, but apparently there was enough for them to do it on this one.
That's crazy. Seeing as the rotors are roughly 15" I would think a lot had to come off.
Here’s my TRX in Hawaii
I went with Black Rhino wheels -18 offset and Yokohama Geolander X-AT 325/60R20
I like these wheels because they are 35.5 in diameter so 1” bigger the 35s at 34.5
I like the ratio, looks proportioned to me
They do rub on drivers side only and when i turn hard left and hit a bump
I can probably trim the plastic and get away with it. But considering a leveling kit
Still have stock wheels and tires
Took Ram bar off. May put it back on. Took tire carrier off. Going to do tonneau cover. And mopar retractable steps
Looks pretty rugged. Black Rhino Raid is what the wheels are. Just remembered
Here is my contribution:
Trimming required: None
Is this across from LifeTime?
Vossen 20” wheels
Thanks for posting the pics. It helps because I’m waiting on 20 inch Weld Ledge 6 wheels which are -18 offset. Going with the 325/60/20 nitto ridge grappler tires. Love the balance and stance of your truck.
Anyone have pics of a black TRX running 37s on 20x9+20 Rebel 6 wheels in anthracite or black? I’d love to see them, thank you
Finally, the new tires showed up - took darn near as long as the 1500 itself.
Anyway, they're Toyo AT IIIs, 295/70R18. Now I'm waiting for a rainy day (Sunday) to mount and balance them. Hoping for a noticeable improvement in lateral stability, but time will tell.
Anyone know what wheels these are?View attachment 22672
I think those were 4Play wheels but that's photoshopped. Not a wheel expert but that's probably max turning radius with that aggressive of an offset.
