Well, this got way out of hand. When I got started, the goal was to gather specs and take a closer look at some of the options we have as TRXs owners. I can now say I’ve looked at ALL the options. Even ones that aren’t really worth considering. Some of the more recent additions:
It’s been a tough process. I held off on a lot of the ones in this latest group the first time around mainly because I couldn’t get a damn bit of information on them. Others are redundant re-labels of filters I’ve already done. But often you don’t know until you get in there.
Some manufacturers just don’t respond or cooperate (Premium Guard, K&N) and others seem totally oblivious to the products they market (aFe). Sleuthing, extrapolating and relying on the “preponderance of evidence” to fill in the boxes where I can, and accepting that some products we will just never know (and therefore shouldn’t waste money on).
Another issue is the rate at which these change manufacturers. Carquest used to use Purolator, now Premium Guard. STP’s XL used to be Premium Guard but is now Champion. K&N now sources a lot of their stuff from Korea and China when before they used Fram and Champion (both now under the same parent company, First Brands).
There’s a chance that what you buy one time will be totally different in materials and spec the next time around. Still, there’s some value in putting these filters on record because you’ll know what to look for and if something changes we can dig into it. So without further ado…
7 of these new additions are made by a Chinese company called Premium Guard. Special thanks to
@hellcatduke for supplying the Carquest Premium (and the Fram Titanium, more on that later).
You have two basic tiers of Premium Guard filter. A cheap one using nitrile gaskets & ADBV, and nicer ones with silicone instead. The higher end ones have higher rated efficiency. At a glance, the media in the $1.97 filter looks no different than the media in the $10.99 one. All of these filters have exactly 69 pleats and the cartridges weigh within a couple grams of each other. The consistency is actually impressive and overall they are put together reasonably well. The media in all three “high end” filters has two stripes on the inside, and the media on the cheap ones has 1 stripe. Really the only difference I could see but it’s enough to somewhat convince me that the higher end ones use a (slightly) different media.
4 new additions are from Fram. The Fram Drive is an Advance Auto exclusive version of the cheap-o Extra Guard and the Force a version of the mid-tier Tough Guard.
The Fram Titanium is very similar to the Ultra and that’s a very good thing. Nice filter. Has a unique “high flow” baseplate, rest is your usual Fram stuff. Wire backed synthetic media.
Lastly, the Fram HP16 is their racing filter. Thing is built like tank and it looks great. Screened bypass and a ton of pleats. Efficiency just isn’t quite as good as I’d like in a street filter but otherwise it’s awesome.
If you really must have a race filter, the Ford Racing one we are covering next is the better choice. More efficient than the HP16 and flows just as well. Also, like the factory MO-899, it has the bypass at the threaded end which would in theory mitigate washing debris off the dirty side of the filter media when in bypass. It’s very obviously made by Purolator (like the MO-899 and regular Motorcraft filters). This thing is too expensive, IMO. But a damn good filter. Side note, my filter cutter met its match with this one (and the HP16). Unreal.
Will hit the rest of these a little more briefly. The Napas are all identical to the Wix versions. I was 99% sure they were so all I had to do was take a look and do some basic measuring to confirm.
Carquest HD and Baldwin B329 are the same filter. Good build quality but nothing that would compel me to use them.
The regular FVP is a regular Wix. The FVP XL is made by Purolator. Don’t have any data on it, but both filters are pretty decent for the low cost. They got a little glue-happy on the XL, though.
Continued…
