*47* RAM TRX / HELLCAT OIL FILTERS CUT & COMPARED
What is your pick of the bunch?
  • Total voters
    305
Just curious why you didn't use the wix filters that are listed for the TRX, 57899/XP and the 57063 which is supposed to be the same as the MO-041. Nice write up tho.
I had to rely heavily on cross referencing because all the parts lookup catalogs for the TRX spec’d the short body filter at the time. This appears to have finally been corrected, which is great news.
The 57899XP will have the same lousy media as the other XP I tested. Unless someone is going 20,000 miles on an oil change, I have no idea why they would want that filter over some of the others.
As for the 57063…I do not think it’s exactly the same as the MO-041 based on pictures I’ve seen, but I will hit it on the next round. I am waiting for the new MO-041 to come out before I cut into anything more.
Which filter does the dealer use when you have the maintenance package? 🤔 Wonder if I need to bring my own filter if they're using the one for the non hellcat ram.
Should be the MO-899. Can’t imagine an actual Ram dealer calling for the wrong filter like these third parties did. I would probably be more concerned with them using the right oil, and doing it correctly to be honest.
Updated the chart on page one. Added several more filters, some by request.
First, we have seen the return of the MO-041 after disappearing for a few months. The new MO-041 and old are materially the same. The only difference...well...it isn't really a good one. The overall build quality. The paint on the new one is thinner, and there's sloppy overspray on the gasket.
This newfound sloppiness is also apparent on the Wix 57063, which is indeed the same filter as the MO-041, inside and out. Same pleat count, same can, same everything. Even the weight of the two filters is within one gram. This is fortuitous for us, because specs are actually available for the Wix version, which completed my chart.
Speaking of completing my chart...the Ford filter. Nobody is going to use it, but I am glad I bought one on a hunch. As noted on page 1, the MO-899 is made by Purolator and has the bypass on the threaded end which is somewhat unusual. You know what other filter is made by Purolator and has the bypass on the threaded end? The Ford / Motorcraft FL-820-S.
The Motorcraft does have a different base plate design, and a silicone anti-drain back valve, but the actual filter and bypass assembly is IDENTICAL by all measures I can perform. Same pleat count, same media, same valve. And since specs from credible sources ARE available for the FL-820-S, we are able to extrapolate these specs to the MO-899 with a good degree of confidence. Yes, Ford and Dodge are selling what amounts to the same filter. But the Dodge one is actually more expensive and uses the inferior nitrile anti-drain back valve. Go figure.
Other additions are far less groundbreaking. Wix 57899 series filters were added, including the new cheapest filter on the chart, the Pro-Tec PXL57899 (made by Wix). The 57899 filters are very similar to the previously reviewed 51372 filters, but with lower bypass pressures and slightly smaller cans.
The Pro-Tec version has little in common with the other WIx filters. Cost cutting is evident in the combined bypass and anti-drain back valve, and consequently a much smaller filter section. In other words, you still get what you pay for.
The last addition was the Hengst H10W18 because I never saw one before. German company, filter made in Ukraine (somehow). Absolutely jam packed with media, pleats glued right to the can and not on a separate assembly. Certainly gives it a ridiculously high surface area. The media, when removed and stretched out was nearly 10 feet long! Unfortunately I can't get specs on it and wouldn't use it anyway. Just an oddball filter I wanted to look at.
I don't plan to test any other filters because I think I've done them all and have become bored with it! BUT if I notice any design changes (or manufacturer changes) with the filters I have already covered, I will post updates and keep this resource alive for everyone.
To my knowledge this is the largest compilation of it’s kind as far as filters for this application. Obviously all of these fit the TRX as well as the Chargers, Challengers and even Hemi Rams (without EPS).
This is not meant to be an argument for what’s best (although I’ve included a poll so you can cast your vote for what you use or will use). I’ve simply gathered all the specs I could find, cut them open and wrote some objective thoughts on what I saw. I bought all of these with my own money, I am not involved in this industry and have no dog in this fight. When shopping I tried to find the best deals on each one but prices will vary.
First spec chart (also available as PDF at bottom of post):
I am limited in attachments so I will post one photo per filter in this main post and stick to the filters one would be most likely to use.
Mopar MO-899:View attachment 39034
Factory equipped. Manufactured by Purolator in USA. Filter portion is identical to the FL-820-S with threaded end bypass. Which is theoretically a slight advantage as when it goes into bypass you aren’t potentially washing the dirty side of the filter into the oil. Pleat spacing is fairly wide and not all that even. The metal internal end-caps aren’t glued extremely tight, it pulled apart very easily compared to the rest. This is not an issue since the spring will hold it together in use, just wanted to make a note of that.
Mopar MO-041:View attachment 39035
This is the OEM+ “upgrade” filter designed for the Viper. Specs are taken from the identical Wix 57063 and overall it's a solid choice I have used in the past. This filter disappeared from stock for a few months but is back and basically identical, but a little less well finished. More on that on page 3.
Mobil M1-210A:
These are now made by Mann & Hummel and share some parts with the Purolators (who are also under that umbrella). Same base plate, ADBV, and dome-end bypass design. Speaking of, I had to call them for the bypass PSI. They said it’s 22 PSI, which would make it the highest here. Good filter surface area and well made. Efficiency is middle of the pack, sold as an extended drain interval filter.
Purolator PureOne PL24651:
The PureOne is a good midrange filter. Very efficient and decent build quality. Much like the MO-899, the metal end caps weren’t very tight on there.
Purolator Boss PLB24651:
This one impressed me. The thing is a tank. Extremely heavy case and tightly spaced media with no flaws. Synthetic media is backed up by a plastic mesh and is super tough and hard to tear. Geared more toward extended drain intervals, the efficiency isn’t at the top of the pack but still very good. I bought it on sale locally for $9.99 and that seems like a a very good deal for what you get. Very nice filter.
Wix 51372XP:
Overall build quality is good with wire backed synthetic media, BUT it is geared solely toward long drain intervals. As such, the efficiency rating is the worst by far. In the independent test chart it did not do much better than rated. In fact, it was off the scale bad. Unfortunately there are much better options with media that provide good flow, good capacity AND better filtration.
Wix 51372:
Pleats are fairly evenly spaced, but put together a bit sloppily with messy glue on the filter media along the seam. It’s a perfectly fine filter though. I would use it over the XP based on the fact that it actually filters.
Fram XG2:
This is the most efficient filter on the market, but it’s a Fram so many dismiss it out of hand. Pleat count isn’t as high, and spacing isn’t quite as pretty as some others, but the synthetic media is double layered, wire-backed and flows very well. These filters also have a very high capacity. Well built.
K&N HP-2010:View attachment 39044
Pretty heavy and well made by Champion Labs (along with the Amsoil and Royal Purple). This one has a synthetic blend media whereas the other two are full synthetic. Unfortunately K&N doesn’t publish efficiency specs, and I feel there are better options for less money. Unless you just gotta have the removal nut!
AMSOIL EAO11:
This one surprised me. It’s easily the most expensive filter here, but the only one made in Mexico. Kind of disappointing. I like the media in this filter, it performs very well. Unfortunately the price has recently been raised to $17.90 (or $22.90 if you aren’t a preferred member) and that’s just too much money for what you get. Compared to the US-built Champion Labs filters like the Royal Purple, the base plate is thinner and lighter with fewer holes. Otherwise construction closely resembles the Royal Purple. Filter media is slightly different though which explains the slightly higher efficiency on this Amsoil.
Royal Purple 20-820:View attachment 39046
Really nice filter. Wire backed synthetic media, heavy baseplate and good build quality, USA made. And not obscenely priced either. Compared to the very similar Amsoil, you don’t give up much and it’s a downright bargain.
In the second post I will share the remaining entry level filters I cut open, as well as some independent flow and efficiency data I found online for a different application…
8/24/2022 Update. Added more filters and updated specs on charts. Added new photos and final thoughts on page 3.
This is just stellar man. Well done.
Yep, I have been running the MO-041 for the last year. It’s a great option, especially for those who don’t want to use aftermarket parts. I also really like the Royal Purple, and will be using one for my oil change next month. Finally, I think the Boss and Fram Ultra are really good and I plan to try them at some point.
Thanks a lot for pulling this together, very useful
The chart doesn't appear to be completely accurate as it claims the bypass spring is less psi on the SRT filter than the standard Mopar. Mopar claims it uses a higher pressure bypass in the SRT and other testers I've seen confirm that.
The Wix 57063 lists a 12 PSI bypass. That is their Viper spec filter and by all measures available to me, it is identical to the MO-041. They are made in the same plant by the same company and directly cross reference to one another. The photos are posted at the top of this page and the measurements in the chart.
Now, maybe Wix is lying about their own bypass pressure. Or maybe Wix only installs a heavy spring on the Mopar version while they are building the two filters side by side for the same exact application. Or maybe the random SRT engineer quote about bypass pressure (without ever providing any actual figures) doesn’t hold up.
I know where logic and common sense takes me. Since Mopar does not directly provide any specs and I am not aware of anyone independently testing bypass pressures (or of an accurate way to do so), that’s what we have to work with.
Any time there is credible data to be added I am happy to update the chart.
And I know where I'd bet, there's very little chance Mopar would claim higher bypass pressure and not provide it. Feel free to ACTUALLY test the spring rate to prove it wrong instead of your rank speculation.
The SRT oil filter for all the past engines and the new 22mm inlet SRT filter for the Gen 4 and beyond engines share the same characteristics. We worked with many of the filter suppliers to get the best features. Some fell out for various performance reasons but we ended up developing the current SRT filters with one of the mainstream manufacturers (it is different than their commercial offerings - or at least was when we developed it). The high flow oil pumps in our large engines (Viper is the biggest) can overpower the internal relief valve. When this valve opens it allows some of the high pressure dirty oil to bypass the filter element in order to keep the filter from being damaged. The SRT filters do indeed have a higher differential bypass valve to make sure all the oil delivered to your powerplant is clean. The housing is slightly thicker than many of the brands out there to handle the pressure but is not the thickest. The real thick ones failed our development testing (fractured at the crimped flange). The media used was one of the latest synthetics that allowed very fine filtration, more debris capacity, and much lower restriction than our standard Mopar filter (and just about every other filter out there)
I’ll let you feel free to set that up. You’re the one calling the data into question. In the meantime, I’m not going to put a random 1 paragraph quote from an “SRT engineer” into the table as if that’s actual data.
For whatever it’s worth, I don’t doubt the MO-041 is a higher flowing filter. So it would theoretically be in bypass less by default. Perhaps that was the engineer’s point.
Either way, there is zero reason Wix would be installing a differently rated bypass spring in two filters made in the same plant, with the same filter media, for the same exact application. When you consider the bypass setting is determined by filter flow, the strength of the media and tube, and engine’s design parameters (oil viscosity, oil pump flow rate and relief setting), it simply doesn’t make any sense.
The purpose of this thread was to collect all the available info and present it in a clear form, take some pictures, and let everyone decide for themselves. I’ve been 100% transparent with where the data comes from, it’s limitations, and the conclusions that can be reasonably drawn. To get hung up on the bypass setting of any filter is to miss the point anyway. It’s one minor factor that’s baked into a filter’s design. Hence the huge variation between brands even though all filters on the chart are for the same application (with a few exceptions).
Logical.
Your efforts on putting together this information is one of the things that makes this my favorite vehicle forum.
I am blown away by the time and money that you put into educating the rest of us about oil filter options.
Since the Jeep 392 has the option of using these filters, it also applies to my wife's vehicle, so thank you thank you. That's a double thank you.
Logical.
Appreciate the kind words. Truthfully most of it was done for my own benefit and entertainment as much as anyone else’s. The cost wasn’t substantial, but I definitely underestimated the time spent and difficulty of getting data. Even some of mainstream aftermarket manufacturers required emails and phone calls for me to get specs. Also found lots of manipulating efficiency numbers and marketing BS to cut through.
My oil pressure is always higher than the bypass pressure. What should we make of this video?
The bypass pressure of a filter is based on pressure differential across the filter, not oil pressure.
Say you have 80 PSI oil pressure and your filter has a 20 PSI bypass setting. As long as the pressure differential across the inlet and outlet of the filter is below the bypass pressure (20 PSI in this example), your filter is filtering all the oil. Scenarios in which the delta P exceeds the bypass pressure (such as a plugged filter or cold, thick oil) will result in the bypass opening to ensure oil flow and protect the filter from blowing out. Even in that case some of the oil is filtered, just not all of it.
The bypass setting for a filter considers not only the engine and oil type, but to a greater extent the filter media, construction and flow. That is why there’s a wide range of bypass pressures on different filters that are all for the same application.
