- Joined
- May 31, 2023
- Messages
- 96
- Gallery
- 2
- Reaction score
- 69
- Location
- Connecticut
- Current Ride
- RM 1500
Well if it's not the clunk, now noticing a grumble/grone cold today, I give up!!!
I don’t think so. Still happening to mine. It’s just one of those issues that’s difficult for dealers to recreate and fix. They were replacing parts on other members trucks but I don’t think we’ve come to a conclusive answer yet. Mine will only do it on the first 1-2 under about half throttle and then it’s gone. I’m still not too worried about it but would like a resolution for it it asap.I know I'm late to this post and hoping it's still open. I just purchased a 2024 Ram 1500 TRX and have that shifting noise when going from 1st to 2nd gear. "the exact issue noted in the video posted Nov 27, 2022 #12". Was the issue/cause ever found?
I have the same thing happening to my truck going from 1st to 2nd under 50-60% throttle. Have taken it in twice now but they couldn’t replicate the issue. But they did tell me they wrote it down on my vehicles file whatever that isNo resolution. Ram said it was normal operating condition. It obviously isn’t, but that was their answer to me. I can recreate the sound virtually anytime I want. Sorry pal…seems like we just have to live w it. Is annoying and embarrassing.
Welcome to the clubJust following up with this thread. Here is mine at the 9 second mark.
Any resolution?
The first time I heard this with a customer, it took a bit to figure it out. Sounds like a wooden chair sliding across a floor? It's in the trans. Performed all the air check tests and found 1/2 clutch test failed. replaced trans with new and customer has never had any issues since. I should mention I am lead engine / performance tech at local dealership.Add another one to the list. My 22 with 29k miles just did this for the first time this morning. Super loud and scared the crap out me. I've been noticing a lag or slip when the truck is cold at very light throttle applications coming from a stop but never anything this bad. Anyone had the transmission replaced as a fix yet?
how low? The are filled from the manufacturer, and the levels are not old school, till it runs out the fill hole. The proper level is 1/8" to 1/4" below the fill hole.My front diff, rear diff, and transfer case were all low from the factory. I would check them all and not just assume they are correct
Between 1/3-1/2 quart low each. When i checked with a pick(about 1/2" long), there was no fluid on it. So i drained and refilled all 3how low? The are filled from the manufacturer, and the levels are not old school, till it runs out the fill hole. The proper level is 1/8" to 1/4" below the fill hole.
@PotterTRX what’s your take on this?how low? The are filled from the manufacturer, and the levels are not old school, till it runs out the fill hole. The proper level is 1/8" to 1/4" below the fill hole.
Finally, someone figured it out. When I take it to my dealership what should I say? Also, the last time I took it to my dealership it would not make the noise on that day. Any advice on how to handle this?The first time I heard this with a customer, it took a bit to figure it out. Sounds like a wooden chair sliding across a floor? It's in the trans. Performed all the air check tests and found 1/2 clutch test failed. replaced trans with new and customer has never had any issues since. I should mention I am lead engine / performance tech at local dealership.
Can you please elaborate on these tests so i can inform my dealer? is it a standard procedure they should have done the first time i brought it in when they were "unable to duplicate" the issue?The first time I heard this with a customer, it took a bit to figure it out. Sounds like a wooden chair sliding across a floor? It's in the trans. Performed all the air check tests and found 1/2 clutch test failed. replaced trans with new and customer has never had any issues since. I should mention I am lead engine / performance tech at local dealership.
Second this request. Dealer has my truck right now for some other stuff as well as this.Can you please elaborate on these tests so i can inform my dealer? is it a standard procedure they should have done the first time i brought it in when they were "unable to duplicate" the issue?
| 1 - Fill Plug |
NOTE: | A full transmission will have fluid at the fill hole with the transmission between 30°C (86°F) and 50°C (122°F). Do not over fill. |
| 1 - Drain Plug |
| 2 - Fill Plug |
Does anybody know how common of a problem this has been?The first time I heard this with a customer, it took a bit to figure it out. Sounds like a wooden chair sliding across a floor? It's in the trans. Performed all the air check tests and found 1/2 clutch test failed. replaced trans with new and customer has never had any issues since. I should mention I am lead engine / performance tech at local dealership.
