Has anyone tried or seen if someone has run a 38" tire?
I have 20x10s (-18) on 37x1350 grapplers. Geiser springs front and back with no rub.
Thanks. I am considering that set up with a level but might do geiser springs instead. Everything about that setup looks perfect for the truck. Just debating 20s or 22s but probably will stick with 20s
Can totally relate , went back and forth for a month. I was about to put my deposit down on my setup with 22x10 vossens and changed at the last moment to the 20 x10 rebels. ( 20 inch vossens were on back order) . I wanted just a bit more side wall and the rebels allowed me to go with the extra inch in tire width. I think you will be happy with either setup!!!
I would need good amount of sidewall too. 22s and 37s would be ok. 22s and 35s wouldn't work for me. I'd get made fun of lol. Likely will do bronze 20 fuel rebels and 37s
I run the Geiser springs with 22in wheels on 35s in the summer and loved the look and ride, just switched to my winter setup with the factory 18s on 37s
For all of you guys running the 35 and 37 ridge grapplers, any wet weather performance issues? I had a set on an f-150 before I got my trx (yep, NEVER going back to any truck other than a rex now… I am ruined for life😂) and they slid a lot in the damp/rain but I dont hear of that problem from any of the guys running them on HD trucks so thinking the heavier trx weight may help avoid that as well?
It rained solid for the first 2 weeks I had the tires and no issues whatsoever . As you mentioned, I believe the weight plays a big factor.
Hey guys, I recently installed some BC Forged wheels with BFG KO2 tires. I tried to keep the weight down and as close to stock as possible. Only gained a few pounds per corner over stock. The factory Wrangler tires are light. I wasn’t able to find a lighter tire than the KO2 in a 35x12.5r22.
BC Forged LE10 - 33.6lbs each
22”x10”
-20 offset
Gloss wheel lip, matte center, gold hardware
BFG KO2 tires - 66lbs each
35x12.5r22
22”x10”
-20 offset
35x12.5r22
Looks awesome!
22”x10”
-20 offset
35x12.5r22
Look great, I really like the painted calipers too.
Stock rims. Shouldn't be any poke. From viewing a ton of pictures poke starts with -12 and more negative. I know 20x10 -18 will poke about a half inch out from the top of the fender.
