- Joined
- Jul 31, 2020
- Messages
- 28
- Gallery
- 2
- Reaction score
- 36
- Location
- Milford, CT
- Current Ride
- 2022 RAM TRX
Yes just check not sure if that is the most current, .........is there a more current version ?Still on version v2022.09 there eh?
If I remember right didn't the 21s come with Uconnect 4? Looking to update mine too but it's a 21.I just checked, and it looks like 2022.09 is still the latest version.
Yeah, the 2021's are different - there's no free download for them.If I remember right didn't the 21s come with Uconnect 4? Looking to update mine too but it's a 21.
Hey there,Couple of tips: Make sure your thumb drive is formatted for FAT32 (not exFAT). And - it's not really apparent on the download site, but there are 9 total files to download. You should end up with a list of files that looks like this on your thumb drive.
With the latest version, there are only 8 files. As long as you download all of them, you should be good.Hey there,
Was curious, I was able to download the .ttpkg files with no problem. The first three files , when I click on download, a bunch of words pop up on the screen but nothing downloads. Instead, I copied the download file and pasted to the thumbdrive. Looks just like on your list. The only file I dont see is the download file at the bottom. Is that a necessary file to be able to update? Sorry if I don't make sense but thank you for any help you may have.
Ahh, good to know @Stonefly, Thanks!I just left my truck engine off and in the on position by hitting the button twice without my foot on the brake. Plugged the usb in and went in the house. Took about 30 minutes or so to update.
obviously you did not have any negative affects to the update? I have a '21, and the map needs to be updated for sure in my opinion. But I also am simply using the standard factory map set up.I wanted to provide an update as I just did the procedure.
You now only need the 5 files on the USB as shown.
You start your truck and plug it in, and it will pop up and ask if you want to install the update.
I tried doing it in the driveway, but the TRX seems to go to sleep so I recommend you do it on a drive longer than 30 minutes.
Don't worry if it gets interrupted it can recover, you just won't have maps until the load completes.
TTNAV.T26.3 with a date of 26JUL23 appears to be the latest.
Hope that helps.
This is a Uconnect 5 update. Not sure if it works with 4.obviously you did not have any negative affects to the update? I have a '21, and the map needs to be updated for sure in my opinion. But I also am simply using the standard factory map set up.
I feel like an idiot, but I downloaded the 5 needed files per the previous thread, and made sure my flash drive is FAT32. I plugged it into each one of my 3 USB ports in my truck and nothing happened. Is there a special port I need to plug it into? Is there a waiting period for it to pop up on the screen so I can download?I haven't had any issues.
Was the truck on?I feel like an idiot, but I downloaded the 5 needed files per the previous thread, and made sure my flash drive is FAT32. I plugged it into each one of my 3 USB ports in my truck and nothing happened. Is there a special port I need to plug it into? Is there a waiting period for it to pop up on the screen so I can download?
Make sure you choose master boot record and not guid partition table when you format it. It won't work if guid partition table is selected. Might of been a fluke but thats what I had to do to get it working.I feel like an idiot, but I downloaded the 5 needed files per the previous thread, and made sure my flash drive is FAT32. I plugged it into each one of my 3 USB ports in my truck and nothing happened. Is there a special port I need to plug it into? Is there a waiting period for it to pop up on the screen so I can download?
I have a '21
This is why. The TomTom map updates are for UC5 on 2022+ Rams. Yours is a 2021 with UC4- different maps.I plugged it into each one of my 3 USB ports in my truck and nothing happened.
