- Joined
- Jul 31, 2020
- Messages
- 28
- Gallery
- 2
- Reaction score
- 36
- Location
- Milford, CT
- Current Ride
- 2022 RAM TRX
Thanks !
Thanks !
do you know how to avoid getting the error we keep getting? Upon plugging in the USB stick, it says something like map files have been altered/changed. Please re-download them & try again.
I got that message as well. I had to reformat my USB drive, using a PC, then transfer the files to the drive. Also, make sure you format the drive correctly. I think it has to be MSFAT32.do you know how to avoid getting the error we keep getting? Upon plugging in the USB stick, it says something like map files have been altered/changed. Please re-download them & try again.
I think ours is already formatted to FAT32 but I'll double check.I got that message as well. I had to reformat my USB drive, using a PC, then transfer the files to the drive. Also, make sure you format the drive correctly. I think it has to be MSFAT32.
Not if you used it on a Mac. Use a pc and do a quick format. Then extract the zip file into the root of the driveI think ours is already formatted to FAT32 but I'll double check.
only options for formatting on the PC is ExFat (not FAT32 or MSFAT)Not if you used it on a Mac. Use a pc and do a quick format. Then extract the zip file into the root of the drive
you can use RufusAny USB stick over 32gb cannot be formatted to fat32. You need to use guiformat.exe if your USB stick is bigger. At least that's what I found.
Ridgecrop Consultants Ltd
Ridgecrop Consultants Ltd - high quality IT consultancy servicesridgecrop.co.uk
