Tazer DT BCM programmer UPDATE: IT WORKS!
Same thing happened to me last year…had to take it to the dealer and have them reflash it…and then I NEVER touched the splash screen option again. Remember you can screw your truck up real fast with this thing. I don’t make any changes unless I can verify somewhere else that it works. But when it does work, it is pretty cool. Good luck.
Yes, I won't say anything if I'm playing with the engine settings or something. But change the splash screen? It is the author's irresponsibility to release something that, by changing something as banal as the Splash screen, can turn a 100,000 car into a brick ! :mad:
Your truck won’t run? Or the splash screen doesn’t work? Bricked is a drastic term if it’s just the screen.
So does anyone else have the radio selection displaying over the settings you're trying to change? I cant hardly get to the setting fast enough before it display the song. What am I missing here?
The Tazer is junk, at least that’s my experience with it. Never should have went to market, to many bugs and issues
I'm sure it's mainly user error due to poor interface design. I'm going to be using it for 3 things amber drl, power mirrors and marker lights. Which im sure 90% of people get it for anyways. Not going to fuck with anything else. I dont know why they add so much fluff that shouldnt be on there especially if its buggy or doesn't work. Like another member said they should have a software program to go on your computer and you can eaisly setup and program everything from there. It wouldnt be that difficult to do that's how alot of hardware devices get customized now a days. Another option is just release a lite version that has the basics turned on you get what you get no customization.
If I only see the time and mileage on the center display, then yes, it's a brick, because I don't see 98% of the things I use every day! Such buggy and unfinished things should just not be part of the app! They should at least be in the "beta" section!
You also see rpm and mph right?
I did the same thing changing the splash. All you have to do is unmarry the tazor do 2 sleep cycles and remarry and it goes back to normal. No biggie. Then just don’t adjust the splash again. Lesson learned lol
I have to try this tomorrow !
Z-Automotive didn't even answer my question through Messenger. It also says something about their reliability. :mad:
When I solved the ADCM calibration with Alpha OBD, I had a beta version for testing within two days!
if you can slip on a shoe with your iPhone or push a nail into the wood with it, does that also mean that it is a full-fledged tool ?
Your argument is dumb. His truck still drives. Engine still out preforms every other truck. His screen doesn’t work. Annoying? Yes. Bricked? No. His truck still serves its primary purposes.
problem solved, thank you!
