Tazer DT BCM programmer UPDATE: IT WORKS!
n8er
TRX of the Month 🏆
TRX of the Year 🏆
Minnesota
Anyone tried this out on a TRX yet? It says 2019+ Ram 1500, but the TRX has a lot of other features that aren’t on the other Ram 1500’s. I don’t want to interfere with those in any way. The main reason I was looking at it was to be able to turn my factory halos off while driving. I got the demon eyes installed and the halos tend to drown them out a bit. There are also some other cool features like auto folding mirrors with ignition, tire size changes, rearcam in signal and some others. If anyone else has tried it, let me know. Or I may have to be the ginea pig for this.
Here is a list of different changes you can make:
Perf menu:
Adjust for alternate tire sizes up to 41″
Adjust for alternate axle gear ratios
Adjust for an alternate transfer case LO range ratio
TPMS menu:
Disable the TPMS system if desired
Change font/rear TPMS warning PSI limit
Radio menu:
  • Disable Backup camera
  • Enable Cargo/front/undercarriage Camera input
  • Enable CD audio input
  • Disable Travellink (weather warnings included)
Lighting Menu
  • Change DRL location
  • Disable DRL Dropout
  • Enable Fog lamp output
  • Disable Fog lamp dropout
  • Disable one-touch lane change
  • Disable Halo’s
  • Set LED 3rd brake light type.
  • Set LED Fog light type
  • Set LED tail lamp type
  • Set LED front turn signal type.
  • Set Trailer Tow output for use with Mopar kit
Other menus
  • Disable/Enable Front and Rear Lockers (for axle swap on Powerwagon)
  • Enable Aux switch settings on the radio
  • Enable Blind spot detection (sensors required)
  • Change cluster splash screen to various Ram models
  • Enable/Disable PANIC button on remote
Live features
  • Light shows: Can be accessed from the key fob or the on-screen menu. Six pre-set light shows, and three make-your-own shows included. Set from the factory to only operate when parked, but can be unlocked for off-road, parade, and emergency personnel use.
  • Automatic Power folding mirrors – mirrors fold and extend when the ignition is turned on/off
  • Control front windows up/down from keyfob
  • Disable Navigation in-motion lockout – enter addresses while the vehicle is moving
  • Disable camera lockout – use the backup camera and/or added cargo/front/undercarriage camera at any speed for any length of time
  • Auto Traction Kill – remembers the last state of traction control and will set it on start-up
  • Auto stop-start Disable – remembers the previous state of ESS system and will set it on start-up
  • Auto Tow Mode – remembers the last state of Tow mode and will set it on start-up
  • TurnCAM – can turn on backup camera whenever turn signals are used
  • 0-30 and 0-60 timers
  • Cooldown mode – run engine fans when Ram is off, to aid in cooldown
  • Winch mode – raise engine idle to 2000 RPM while winching or jumping another vehicle
  • Line Lock: Can lock front brakes for an easy burnout
  • Rock Crawl: Can lock all four brakes by pressing steering wheel buttons to hold the vehicle still, especially helpful when off-road.
  • Button Mapping: Use cruise up, down and right buttons as quick-access to some of Tazer DT’s functions, when cruise control is off
  • Clear Check engine light
Perf menu:
TPMS menu:
Radio menu:
Lighting Menu
  • Disable Halo’s
Other menus
Live features
Thanks for volunteering. Let us know how it works. Cheers
Perf menu:
TPMS menu:
Radio menu:
Lighting Menu
  • Disable Halo’s
Other menus
Live features
I see what I need... Does it also let you use 360 camera's at any speed?
Does this work with the oe ui?
Love my Tazer in my Rubicon, greatly needed to stop them damn start/stop system in the Jeep, and love the engine RPM increase while using my winch!
Can it disable the seatbelt dinger? I hate cars telling me what to do. It’s like “I own you bitch! Don’t tell me what to do. The fuck you think you are?”
Anyone ever tell you that you might have issues.....🤣
Too many therapists and psychiatrists. I have a binder full of diagnoses but it makes me unique and special. My mom said so!
Got my Tazer DT sitting here.........waiting on the truck to be built & to me.
I talked with the guys at Zauto - should work!
That’s awesome as I wouldn’t mind getting one, can you define “should”? Thanks
"should"......not sure how to really clarify that.
It is assumed to work, as the truck is a DT......and the BCM is the same, just (obviously) some changes for TRX stuff......but the rest is the same.
Anyone in STL? Bring your TRX to me, I'll check if it works!
I just installed yesterday and it seems to work. Features I'm using:
  • Disable Halos. Works. Wanted to disable to let the demon eyes shine.
  • Mirror auto fold: I like this feature, especially since I have the tow mirrors and they stick out a little more than the standard ones.
  • TurnCAM. This one I have to get a little more info on. When I hit the blinker, my FRONT camera goes on along with the 360 camera. I'd rather have the split screen mirror cams that I could activate in my 2500. I'll have to play a bit with it.
  • Disable fog dropout. Now when high beams turn on, fog lights stay on.
  • Disable seatbelt chime. @Bambi This one's for you!
These features I probably won't use regularly, but I checked them out:
  • Set Tire Size: I was interested to see how this works, as the TRX has bigger tires than the other ram 1500's. However, when I went into change the size, the current size read 35.03, so it looks like it is reading it from the computer on the truck. I'll play with this more if/when I put 37's on.
  • Windows from Key Fob: To lower windows, you hit unlock 5 times and the windows go down. Lock 5 times and they go up. At first I thought the function wasn't working, because I hit it 5 times fast and nothing happened. Well, If you go too fast, the truck can't keep up, so you kind of have to hit it about once a second, and it works.
  • Light Show: Haven't done any custom setups, but tried the ones already programmed. I used the key fob, and as with the window feature, you have to wait a second between pushes of the button. Unlock-Unlock-Lock-Unlock activates and Unlock changes light shows. Lock stops the show.
These are really the only features I dug into, as it was late last night by the time I was able to get it installed. Easy install, though. If you guys want me to check on any other features, let me know, and I'll check it out.
Who was it that wanted Amber colored Halos? Well, in the DT programmer, you can change the location of the DRLs. I changed it to the turn signal and tada! I have Amber halos.
How do the demon eyes look with the amber drl on? Also, how do the turn signals look when set as the drl?
This looks like a lot of fun! Added to the list of things I need to buy once the truck actually shows up! Thanks.
I’m buying this just for the seatbelt dinger. Link?
I have no clue yet. The idea popped in my head when I was writing my first post today, so I just ran out, changed the settings, and checked if it worked.
