Shifts And Grins Reverse Light Brackets And Diode Dynamics Lights
Just to make sure I’m looking at the PnP harness right: it taps into the trailer connection, but still provides a trailer connection (thus not affecting the ability to connect a trailer), right?
Yes, he is building the same basic harness that I made. It has male and female 7 pin connectors that tee into the factory wiring. Everything still passes through to the stock trailer connection.
You are correct.
I'm also happy to provide part numbers or links and a little write up if someone wants to make their own. I have no issues with that at all.
We are here to support you guys and appreciate the support you give back in return. If the plug and portion is something people want to tackle on their own, I have no issues helping people with that. I'm going to be away from the computer for several hours for an Easter get together with friends and family but sometime this afternoon or tonight I can do a write up and provide links.
What @Eighty said. I built a few harnesses to test that make it plug and play. They will/would be and add on to your harness that came with your kit. There was a concern that the truck may think there was a trailer attached and I didn’t want to start shipping them before knowing if that was case. I have a TRX and a Rebel I built those harnesses for already to test them on since I’m doing installs on those trucks soon. It looks like @OnTheReel did the dirty work and beat all of us to the punch. Lol. If anyone wants the plug and play harnesses I’ll do my best to have several of those ready and on the webpage by the end of next weekend. I ordered enough materials to test them but it looks like that will be a popular option so I’ll get more coming immediately and build them out as soon as the materials are here.
Can you let me know when they are ready? I need to purchase a kit.
That would be great. I have with white lights instead of red that I was going to tap into the reserve wire of the trailer harness like mirror tap kit for radar detectors and then run the main light to my Aux switch but this would be nice if I can figure out the Aux switch side of that harness.
As soon as I get the TRX in I'll do a post on wiring it to the Aux Switches for these lights as well. This may also help in the meantime.
Thanks, I have my front Oracle light tied into Aux 1, I didn't word that very well just have to figure out the harness for the double diode light to work how I want.
Got it. I'll do write up on the wiring soon. There will also be a youtube video or two showing that soon as well.
Here is an Amazon link to the harness I started with.
Below is a wiring diagram for the 5 flat trailer harness that is part of the link above.
Next is the wiring diagram and a photo of the wiring harness the kit already comes with.
To start, take your Curt adapter harness which will be the Plug and Play portion of the harness and locate the connector that has five wires and a flat connecter.
Cut the blue and brown wires in this harness. (Note the wiring diagram above shows the blue as purple). Next I stripped the wires and slipped heat shrink tubing over the wires. I crimped the male ends(*******USE FEMALE ENDS*******I PUT THE WRONG ONES ON FIRST) on to the wires and then soldered them as well. You don't have to solder them but I always prefer to. After crimping and soldering the male ends on to the blue and brown wires, I slid the heat shrink up and heated it up to cover the soldered end.
Next I removed the unused wires and plug from the harness by removing the plastic loom that came on the harness and cutting them short near the connection points. I placed heat shrink over the ends and heated them up. The last thing I did to prepare the harness was slip some Alex Tech Expandable Sleeving over the wires and used electrical tape and heat shrink to secure the ends of the expandable sleeving over the wires.
Your plug and play harness is now built. Now onto the install.
Disconnect your connector that plugs into your trailer light plug behind the bumper on your truck. Plug the trucks wiring harness into one side of your new plug and play harness and the other side of your plug and play harness to the trailer lights connector on the back side of your bumper. Now take your Diode Dynamics Reverse Light Wiring Harness and plug the Yellow Wire from your Diode Harness into the Blue Wire of you plug and play harness. Plug the Blue Wire of your Diode harness into the Brown Wire of your Plug and play harness. (I know, I know it feels like Blue should connect to blue to me as well but I am working with two harnesses from two manufacturers so in this case Blue DOES NOT connect to blue. Sorry ladies and gentlemen.)
Now you can connect the plugs on your Diode Dynamics Reverse Light Harness to your Lights. Run the rest of the harness to the front of the truck. You have a few options at this point.
Option 1:
You can hook up the power and ground wires respectively from your Diode Dynamics harness and coil up the remaining wires and switch and be done. If you leave the switch in the center neutral position your lights will work automatically.
Option 2: You can do exactly as you did above but route the wires inside the truck and mount the switch at your desired location inside. This will give you the option to have the lights work automatically when the switch is in the neutral position, Turn on the white main beam by flipping the switch to one position or manually turn on the red back lights by flipping the switch the opposite position.
Option 3: You can ditch the switch with Diode Harness and wire in to the auxiliary/upfitter switches. There are already writeups and videos on that but if I need to update this with specifics, I will.
Let me know if I left anything out or if you have any specific questions. The harness isn't terribly hard to build and I hope this helps anyone that would like to save money and do it themselves. There are shortcuts and easier ways to build it but I don't work that way. If I am building something for you or me, I will take the time and do it the way I feel is best.
I will make several of these harnesses for people that wish to buy them from me. Full transparency they aren't that expensive to build but I have to charge for the time it takes me as well. My cost on the materials is close to but a little less than $40 per plug and play harness. That does not include the Diode Dynamics Harness. I will build a few more to come up with a price I feel is fair for my time and get them up on the site.
Thank you all for the support and I hope this helps some of you that want to do it on your own! It is my way of giving back when and where I can.
View attachment 39853View attachment 39854
Cut the blue and brown wires in this harness. (Note the wiring diagram above shows the blue as purple). Next I stripped the wires and slipped heat shrink tubing over the wires. I crimped the male ends on to the wires and then soldered them as well. You don't have to solder them but I always prefer to. After crimping and soldering the male ends on to the blue and brown wires, I slid the heat shrink up and heated it up to cover the soldered end.
View attachment 39873View attachment 39874View attachment 39875View attachment 39876
View attachment 39877View attachment 39878
Option 1:
I'm interested in wiring the lights to an aux switch so they can be controlled when not in reverse but also have the lights come on when in reverse as well as the red backlight at night. Will this be possible with the harness you are building? Also, will I have to connect your harness to the trailer connector or can it be wired in while leaving the trailer connector free? I know I can splice if needed but asking about your plug and play option. My TRX hasn't arrived yet so I can't look at it to know my options.
With this kit you can wire it exactly how you want. You can use the Aux switches to control the main light manually and the red back light manually but that would take another switch to do. The red back light would still come on automatically with your tail lights and the main beam would still come on automatically with your reverse lights. As far as the plug and play harness goes, it is basically a T harness that is behind the bumper and does not affect the ability to use your trailer connector while towing a trailer. The reason for the plug and play harness is prevent having to splice into your vehicles harness in any way. It doesn't affect the operation of the trailer lights or plug in any way. I hope I answered all of your questions. If I didn't or you have more, ask away! Thank you for the question.
This is exactly what I want. I remember reading somewhere the harness needed a diode to protect the truck in the event you were to accidentally turn on the aux button that controls the lights while in reverse. I assume this harness offers this protection?
If you turned the switch on while while the vehicle was in reverse, it would not cause any damage. I think the mention of diode was possibly referring to it back feeding the reverse lights with the switch activated causing the reverse lights to turn on. I'm not 100% sure but I think the Diode Dynamics harness has a diode in it already to prevent this. If it doesn't, the worse case scenario for this would be the reverse lights turning on as well from being back fed voltage. I will have to test the manual activation of the lights when I do my first full install here soon and see if it turns on the reverse lights too. I don't think it will though........I just can't be 100% sure until I test it. This harness (The Diode Dynamics Reverse Light Harness that is included in the kit) has been used on numerous applications for many years. It is a tried and true harness and I am confident it will not cause any issues. The plug and play portion doesn't change anything in the function it only prevents the need to splice your factory harness.
Perfect, let me know when the plug and play portion is ready so I can grab one.
I should have three ready by the end of the night. I ordered more materials as well and will get them up on the webpage soon. Thank you Kevin!
