Eibach Pro-lift installed
Awesome write up man! I’m definitely going with the pro lift and 37s because that’s how this truck should look. Thanks to everyone who contributed with important info and your thoughts 👍
Refreshing this thread for anyone on the fence. I was lucky enough to meet @ORCowboy (and his wonderful wife) yesterday and see his truck. The stance with 37’s and the Pro-Lift is perfect. It doesn’t look “over lifted” at all, it is fairly subtle. Kinda like, why does this stance look so much better than the others I have seen? His truck is the best looking TRX I’ve seen in person. Besides the $$ I spent on his Beadlocks, he cost me several more thousand $$ in bumpers, lights, tires, springs, ……..😂😂
Thanks GFam! It was great meeting you and your son as well. Will be watching for him playing at UO in the future, and at his size maybe onto pro ball. Will PM you with some of the installers i used in the area. All great guys that I’ve worked with for years.
Best of luck to you getting your new 23 soon. Will keep watch for your review and many mods are to be expected!
I'm running 37x12.5 on stock wheels and just the 1.6 front Eibach springs.
How tall is your garage opening and how much clearance do you have with the 1.6 level kit and 37s? Wondering if this will fit in a 7ft standard garage.
I will measure my garage for you later this morning. I clear the fin by about 1/2". I just just have to make sure that I don't pull into the middle or my fin hits the garage door opener.
Has anyone done the 1.6 front springs and 1.5 rear springs? I figured that’s the most subtle lift. Plan on running 37x12.50r18 on +3 offset methods I have now.
Awesome! Thank you! If you have some pics too, that would be great. I'm in the DFW area too, so I'm hoping our garages are similar and I can pull off the same setup!
My garage opening is 82" tall so 7ft should leave you plenty of room.
I don't have any pictures showing the height. Length was my main issue. Before my ADD bumpers, I had 1/8th in front and 1/8th in back when my garage was closed. I gained an extra 1.5 to 2" with the aftermarket bumpers
Awesome news! Appreciate you taking the time to measure. Thank you!
I did the install last Friday, I think the front is 1.9 and rear is 1.5, anyways.. the front measures 41.5' from ground to bottom of plastic fender flare, and rear measures 42'. The ride is amazing, better then stock!
I did the install last Friday, I think the front is 1.9 and rear is 1.5, anyways.. the front measures 41.5' from ground to bottom of plastic fender flare, and rear measures 42'. The ride is amazing, better than stock!
Pics or it didn’t happen 😎
If the 2.7" front spring only lifts the front 1.9", I wonder how much the 1.6" front spring actually lifts the front.
I think they meant to say that the original front level springs were 1.9” advertised and the second batch was 1.6” for some reason. I have the level springs from the first batch. Not sure what or if anything was changed tbh
I thought he did the 2.7 front and 1.5 rear like OP not the 1.6 and 1.5.
How much lift did you get out of your (1.9" or 1.6") front springs?
I am 42 in the front and 41 5/8 in the back with 1.6 fronts with a ADD bumper and winch.
I honestly have never measured lol. But it is pretty level from the front to rear.
I just got the front (1.6) & rear (1.5) Eibachs installed this afternoon. Have about 40 miles clocked so far but i can say it rides MUCH nicer so far. Doesnt seem to get so unsettled & angry on breaks in pavement/etc. Very smooth so far. Hit my speed hump at only 20mph so ill post more feedback after more time. Planning to do some hi speed offroad this week/wknd
I did do a few measurements though. Ground clearance at lowest bash plate bolt head went from 12.5” to 13.75” and rear hitch skid to ground gained about 1.25” as well.
Very subtle lift for sure. Exactly what i was looking for. Looks like stock fender travel when i had 35s.
Also- CV axle angle looks identical to stock. Very happy with that!
