The ride quality on the “lift” springs (2.7 fronts & 1.5 rears) is pretty good. Much flatter in corners. Truck feels more solid and just slightly less floaty over bigger bumps. I have noticed, on small imperfections in the road, the truck feels a little squirrelly, just for a split second. I have not recalibrated the height sensors yet. I tried to reset the suspension in AlfaOBD, but it does not seem to have had any effect. Dealer said they’ll recalibrate for $160…I’ll go that route at my next oil change and see if that changes anything. Was considering purchasing the RC kit, just to use the height sensor relocation brackets…someone should come out with a TRX Spec bracket for everyone to use. One that would get you closer to a stock location, between 1.5” to 2” of lift in the front! Heck, maybe even one that had a few holes for adjustment. Sensor relocation options for lifts of 1.5”, 2” and Gieser’s 3”…or, even better and cheaper, replacement sensor rods like the 5th gen air suspension guys use to adjust ride height on the reg Ram 1500’s…just a small, cheap tie rod with ball cups on either side. I would have fab’d one up, but I don’t know the stock location/angle of the sensor arm before the lift…that would solve the issue of a dead battery, necessitating sensor recal again, in that situation…
