1/4 Mile Times 🏁
Thanks, you too.
Everything listed above in my first post. That was a nice cool October night so air was good but it’s pretty consistent with the stage 2 inter chiller.
Do you or did you have any startup issues when the temp is hot and humid with the FI Interchiller?
I just finished the install in October so haven’t had much humidity here in IL yet.
Either Curt Dusterhoff or Kirk from FI explained to me that when humid there may be a window between like 45 and 2 hours after shutdown that it may have startup issues due to condensation built up in/on intercoolers. I have noticed some slight stumbles on startup but has never failed to start. I suspect it will be worse with high humidity. I try to hit it with a little boost to clear it out before shutting down
Yep, mine doesn’t like to start under humid conditions 45 min to about 2 hours after running. It will start, but usually takes a couple of attempts. Shutting off the interchiller/ac and hitting it with a little boost does the trick if you let the IC Coolant get to at least ambient temp before shutting off. Kirk at FI swears it is fixable via the tune by adding fuel, however Curt Dusterhoff is equally as certain it cannot be fixed via tune.
I’m not sure how to post on a forum but wanted to share my setup and results.
Indianapolis Raceway Park
1/4 mile 10.482 at 128.46
2.65 upper 10% ATI lower (pinned)
E85, 1200 injectors, BAP
Kong full port blower with stock TB
BWoody CAI modified to fit IC reservoir
FI stage 2 interchiller with 3 gallon reservoir
30” Hoosier DR2
View attachment 56428View attachment 56429
nice ride. thanks for posting I was curious where I could be at with a set of proper tires I have a very similar build to you.
Nice run
30” Hoosier DR2
Nice Run! Curious though; why a full port blower with a stock TB?
South Georgia MotorSports Park
12.46@109
Stock tires
100% stock
12/4/22
Maybe we should add a line for RPM and launch control vs brake boost. Would be nice to put that debate to bed with some legit data!
Stock
1/2 tank fuel
Myself and 1 passenger
Still need to make a visit to get a slip one of these days.
Stock
1/2 tank fuel
Good times
Is your truck complete stock ? Here is my best stock time
