ZenCarbonFiber Stitched Airbag Cover Installed!
He finally responded and apologized for being out of town during July 4th. Don’t see how that is an excuse for not responding to my communications since May.
His team also lost the OEM airbag cover I provided. :rolleyes:
All,
How are your Zencarbonfiber products holding up? About to pull the trigger on their leather cover but its for my Challenger. Same design really.
All,
No issues with mine, but I only have 4K miles on the truck and it spends most of its life in the garage. Fit and finish are excellent. My only gripe is the mismatched black chrome vs gunmetal, but I don't notice it anymore.
First, this one is not for the faint of heart. Since there was literally nothing online and no instructions included I was really on my own. The concept is simple, it’s a stitched replacement cover for your factory airbag. Execution on the other hand took me a few hours.
I won’t go into removing the airbag because there’s no shortage of videos. It’s a pain in the ass but I’ve had it off a few times now and it was definitely the easiest part of this job.
With the airbag out, I started trying to figure out how the hell this all comes apart. Looking at the perimeter of the airbag, you can see metal tabs around the airbag and plastic tabs that hold the cover on.
The metal tabs lock the plastic tabs in place. The only way I could work out is that you bend the metal tabs back which allows the plastic tabs to slide over the metal and come off. The metal is quite pliable so a small flathead and some careful bending eventually freed the original cover up.
But wait, there’s more! The cover they sent had the standard Ram “bright metal” emblem, not the black chrome. So I had to move the emblem over. It is plastic-welded in, so I used a dremel to grind these green plastic posts flush with the airbag cover and it came right off.
To re-install the old badge on the new cover I elected to use CA glue and activator, a product I’ve had great luck with on most of the plastic crap Ram makes. It cures instantly and holds very strong so I don’t anticipate it flying off and hitting me in the face if I wreck. Probably would be the least of my troubles anyway.
After the badge was installed, I just had to slide the new cover over the airbag until all the tabs caught, and then bend the tabs back. Reconnect everything and re-install.
The finished product:
View attachment 122026View attachment 122028View attachment 122029View attachment 122034
Overall it looks great. I requested matching stitching and they nailed it, perfect match. The alcantara also matches the factory stuff perfectly. In the pics the factory alcantara on the wheel is a bit wet from cleaning, but when dry it matched 100%.
I have no issue with the quality or end result, but the install was a bitch, no other way to put it. It’s never comfortable working with airbags, even with the battery disconnected. Even worse when there’s no directions to follow.
If you order one I would suggest you ask them to include the black chrome badge from the start, it’ll save ya some time messing with that at least. So there’s my 2 cents on how I did it and what I think.
What was the original reason for replacing the cover? New one looks nice though
Just installed mine! Thanks to @vipermike626 for the killer deal.
Only had mine for couple weeks but like it so far.
