TRX Stock Wheel specifications - Offset, etc.
Does anyone know how the beadlock wheel is made?
Is it forged like the beadlock rings?
Is it “flow forged” with a machined or billet center?
Is if cast center with a “flow forged” rim?
So many oem wheels are billet machined or forged and machined.
My truck is still at the dealer so I can’t see them.
Wondering how much does weight matter? Does anyone know the weight of the stock black wheels, as well as the weight of the stock GY tires?
I have fuel Covert wheels ready to go for when my TRX arrives, and TOYO AT3's.
I am considering returning the coverts and getting the Vosssen HF6-4, 20', 9.5's though.
They are so fkn tight. Just like Molly on that first night when I was 15.
Anyway...I digress.
I would like to get my information together for all of these wheel combos that I am considering, and am hoping to force a better decision based on some feedback about this.
Any help is appreciated!
Anyway...I digress.
Some people say they notice a difference with a heavier wheel and tire combo. I'm not so sure it would be terribly noticeable on this truck given the power it has. On a smaller car (like a race car), I can certainly see how a few pounds per corner of unsprung weight could make a difference, but on this big truck I think it would have less of an effect. Unless you are racing it and trying to ring every ounce of performance out of it I'd say go with the wheel that you like the look of the best.
Anyway...I digress.
I'm trying to find something that's still an A/T but could potentially have better traction for the 1000whp+ mark. The "best" tire I have been able to see thus far is the new Nitto Recon Grappler, but they come in at 71lbs per tire for the 325/65R18, which makes them 7lbs heavier per tire than the stock GY's. I was looking into getting some lighter wheels to compensate, but it looks like I'd still net something in the range of 4lbs per wheel/tire, not sure if it will have a noticeable decrease in acceleration or if the "better" tire will help enough in the traction department to make for a better launch. Tough decision to make, lots of $ to potentially lose performance. But alas, I refuse to put on a street tire because I don't like the way it looks.
As you know, I think you could throw a lot of $ into trying to find the optimal AT tire that balances weight and traction. The GY Wrangler Territory is probably going to be the lightest tire by a pretty wide margin. It looks to be in the low 60lbs. range where as everything else is 10lbs heavier.
I'm sure you have also already contemplated playing with rim width and diameter to increase traction, which can also get expensive. I'm just wondering if maybe an 18x11 forged wheel might allow a little flatter tread pattern, while staying in the same weight range (or less) for wheel/tire package. Unless you know for a fact the GY tread is worse at hooking up than another AT tread I'm not sure your net gain by going to another AT tire would be very significant.
Does anyone know what offsets will work with 18 inch rims? I have been looking at getting some beadlocks but they have a -44 offset and I have a feeling that is not going to fit
Stock is +19
Yeah I now the stock offset......but trying to figure out what will fit on stock hieght
I found this set up...I love...but it requires a 2 in leveling kit
Ahhh. Yea.
Poking wheels and tires is an interesting thing. Wish I could help.
But I am up in the air...seems like 2023 is the last year of the TRX with the current Engine. I have 6K miles on mine. Its a 2021. So not entirely sure if I want to try and get a 2023 or made some mods to mine and keep it. I am sad that everything is going electric. I live in an area where electric will not really work.....mountainous remote area. Most have diesel trucks....for bulling campers, trailers, campers.....
In all the info provided I have not seen info on factory center cap hole. So in true figure it out fashion I ordered a few to test. 63mm is the cap that seems to fit same center as Charger and Challenger. If anyone is looking for a center cap. I'm setting up a set of factory beadlock wheels. I will post tire and wheel weight and factory non beadlock wheel and tire weight. I will also post weight of complete beadlocks with beauty rings and bolts. Give me a couple days to figure the weights out.
Ok tid bit of more info. My new tires and factory beadlocks weigh in at 113 pounds. Tires weigh in at 71 pounds trim ring is 3.5 pounds 12 bolts 1 pound. Total weight of factory beadlock wheel is roughly 45 pounds. My total unsprung weight on each corner about 118 pounds. I will get the weight of stock tires and wheels as soon as I get them off...
Post some pictures of your truck once you get those tires mounted please. I'm looking at those tires and have yet to see a 37x12.5x18 on a TRX. I'm trying to decide between those and the more aggressive looking A/T Ridge Grapplers.
I don’t have the toyo at3 but I do have the toyo rt in 37x12.5r18. Pretty close.
View attachment 104738View attachment 104737
Thanks. I've seen yours., looks great. I'm guessing the first pic was at OC Cars and Coffee.
I really like that tire but leaning towards a true A/T just for longevity's sake. How's tire wear and road noise with those?
Yep it was! My little dudes first car event.
I have just over 10k on mine and they’re still in amazing shape. I’ve been really surprised how well they are wearing. They’re about the same as stock for road noise.
