Just trying to confirm weight if I’m gonna spend money on wheels I want to make sure I’m cutting down rotational massI don't know the weight of the rim, I think it is about 38 to 40 lbs. The bolt pattern is 6x139.7 and the offset is +19. I bought 18 inch Black Rhino Beaded rims with and offset of +12 and put 37 inch Toyo Tires and have no issues.
How's the ride? Louder? Speed issues? *looks AWESOME.I don't know the weight of the rim, I think it is about 38 to 40 lbs. The bolt pattern is 6x139.7 and the offset is +19. I bought 18 inch Black Rhino Beaded rims with and offset of +12 and put 37 inch Toyo Tires and have no issues.
Thanks! The ride is the same as factory, Toyo makes a quiet nice tire Open Country AT2, no issues at all and there was no changes to the truck to fit the tires I believe the tires are 37x18x12 .How's the ride? Louder? Speed issues? *looks AWESOME.
i have been searching trying to find the answer before post but no luck sooo...Anyone know the weight of the stock non beadlock rim?
They are 30lbs.i have been searching trying to find the answer before post but no luck sooo...
Does anyone know the weight of the stock wheel non-beadlock?
Most 18s will fit but I would only buy from a company that has tested fitted to confirm as not every 18 fits.Has anyone found wheels that do clear the calipers? We are looking at 4Play wheels. They said 18s or 20s might...but not sure. Those calipers barely clear the stock.
These are all beautiful rims but are they primarly for street use? Any thougts on Braid, I was thinking about the Winrace Beadlock, possibly forged? I will spec it same as the factory rim, love the way the TRX rides and dont want to change it.I have a feeling you are correct about fitment. No rub for normal driving, but hard off-road will likely impact. I went with nearly factory wheel offset and same width (20x9), but a 13.50 wide tire. That might be an issue, but again I'll report back.
For the lightest wheel you would probably want a forged wheel. Forged gets more pricey, but several manufacturers will custom make them in any size, offset, etc. Check out Anrky, HRE, Vossen, AG Luxury. I can get you Anrky if you are interested. They only have one wheel option though. Innov8 Racing also makes forged wheels, but I don't think they make them custom offset. Method makes several reasonably priced wheels in the correct width and offset. They aren't forged though. Fuel also makes several wheels in the correct width and offset.
Lots of guys have run these wheels (Fuel, Method, Black Rhino, KMC, etc.) off road without issue. Raptor guys have been running Methods and Fuels for years without much issue. That's not to say they are the strongest option out there, but generally speaking they are durable enough for most applications. There are certainly stronger wheels (such as forged, as you mentioned), but other than a few quirky design flaws (like the KMC Rockstar that consistently cracked at the spoke on heavy trucks causing a small leak) the cast are generally fine.These are all beautiful rims but are they primarly for street use? Any thougts on Braid, I was thinking about the Winrace Beadlock, possibly forged? I will spec it same as the factory rim, love the way the TRX rides and dont want to change it.
Thank you for a very detailed and thoughtful response, very much appreciated.Lots of guys have run these wheels (Fuel, Method, Black Rhino, KMC, etc.) off road without issue. Raptor guys have been running Methods and Fuels for years without much issue. That's not to say they are the strongest option out there, but generally speaking they are durable enough for most applications. There are certainly stronger wheels (such as forged, as you mentioned), but other than a few quirky design flaws (like the KMC Rockstar that consistently cracked at the spoke on heavy trucks causing a small leak) the cast are generally fine.
I was not familiar with the Braid wheels, but I checked out their website. The Winrace Beadlock is a pretty cool looking wheel. The description calls it a cast monoblock wheel, which is the same thing as most of the Fuel, Method, BR, etc. However, it says the load rating is 1,760lbs. which is actually lower than most of the other wheels from the manufacturers I listed. Most Fuel cast wheels are load rated at 2,300lbs. If you went with something forged like an Innovate your weight rating would go up to 2,600lbs., but you could not get a true beadlock because they only offer true beadlocks in 17" diameter. Braid does seem to offer the Forged 4x4 wheel with a beadlock option in a 20" wheel, but I wasn't able to find a weight rating on them.
One other thing to consider: Unless you regularly go offroad and air down the tires to single digit levels then you might reconsider running a true beadlock. They require a considerable amount more maintenance such as retourqing the beadlock bolts every 250 miles. On a street driven truck that is a real PITA. You could skip that requirement, but then you open yourself to more issues like slow leaks, or worse case, a catastrophic failure that results in a blown/unseated tire when you are driving. That's not really a hassle most people want to deal with.
I took a look at your website (I think) - do you sell wheels and if yes, which brands?Lots of guys have run these wheels (Fuel, Method, Black Rhino, KMC, etc.) off road without issue. Raptor guys have been running Methods and Fuels for years without much issue. That's not to say they are the strongest option out there, but generally speaking they are durable enough for most applications. There are certainly stronger wheels (such as forged, as you mentioned), but other than a few quirky design flaws (like the KMC Rockstar that consistently cracked at the spoke on heavy trucks causing a small leak) the cast are generally fine.
I do. I'm in the process of revamping my website to show more of the brands I carry, but I have all the usual brands (Fuel, KMC, Method, Black Rhino, Weld, etc.). I also have some of the more custom brands (ANRKY, AG Luxury, Rotiform, ADV1, KG1 Forged, Vossen, Rohana, etc.). Is there a particular wheel you are looking for, or you just trying to narrow down some options?I took a look at your website (I think) - do you sell wheels and if yes, which brands?
Thanks
did these come hub centric or did they provide you with a hub centric ring?I don't know the weight of the rim, I think it is about 38 to 40 lbs. The bolt pattern is 6x139.7 and the offset is +19. I bought 18 inch Black Rhino Beaded rims with and offset of +12 and put 37 inch Toyo Tires and have no issues.
Narrow down some options - what is best way to connect directly.I do. I'm in the process of revamping my website to show more of the brands I carry, but I have all the usual brands (Fuel, KMC, Method, Black Rhino, Weld, etc.). I also have some of the more custom brands (ANRKY, AG Luxury, Rotiform, ADV1, KG1 Forged, Vossen, Rohana, etc.). Is there a particular wheel you are looking for, or you just trying to narrow down some options?
I shot you a DM with my number. I look forward to speaking with you.Narrow down some options - what is best way to connect directly.
Thanks
Correct! See first post.Hey all quick question I see our bolt pattern is 6x139.7. Is that the same as 6x5.5? You know metric vs standard?
Thanks in advance!
