Tazer DT
So first, please excuse the ignorance. I’ve never owned a Tazer for any vehicle. But I’ve been reading this thread and I’m intrigued, once I have a vehicle. Is there a list of available “hacks” somewhere of what all it can do? Seems like the seatbelt chime, DRLs and folding mirrors are the most popular but is that all? Seems hard to justify price for just those three items. TIA!
Tazer DT is an essential tool for owners of the new 2019 and up Ram 1500 (New Body Style Only, including Ram TRX)
Simple, plug-in installation – simply unplug the SGW module and plug the Tazer DT Mini in its place. It is easily accessible, located above the OBD2 Diagnostic connector.
There are two sets of features – those that program the vehicle to accommodate modifications made to the Ram, and “live” features.
These are all accessed using the dash display, using steering wheel buttons to navigate the menus.
Settings – once the Tazer is “married” to the Ram, the following menus can be accessed. Unmarrying the Tazer DT will bring the settings back to stock.
Perf menu:
Adjust for alternate tire sizes up to 41″
Adjust for alternate axle gear ratios
Adjust for an alternate transfer case LO range ratio
TPMS menu:
Disable the TPMS system if desired
Change font/rear TPMS warning PSI limit
Radio menu:
  • Disable Backup camera
  • Enable Cargo/front/undercarriage Camera input
  • Enable CD audio input
  • Disable Travellink (weather warnings included)
Lighting Menu
  • Change DRL location
  • Disable DRL Dropout
  • Enable Fog lamp output
  • Disable Fog lamp dropout
  • Disable one-touch lane change
  • Disable Halo’s
  • Set LED 3rd brake light type.
  • Set LED Fog light type
  • Set LED tail lamp type
  • Set LED front turn signal type.
  • Set Trailer Tow output for use with Mopar kit
Other menus
  • Enable Aux switch settings on the radio
  • Enable Blind spot detection (sensors required)
  • Change cluster splash screen to various Ram models
  • Enable/Disable PANIC button on remote
  • Enable Power Side Step for those installing Mopar kit
Live features
  • Light shows: Can be accessed from the key fob or the on-screen menu. Six pre-set light shows, and three make-your-own shows included. Set from the factory to only operate when parked, but can be unlocked for off-road, parade, and emergency personnel use.
  • Automatic Power folding mirrors – mirrors fold and extend when the ignition is turned on/off
  • Control front windows up/down from keyfob (EXPERIMENTAL)
  • Disable Navigation in-motion lockout – enter addresses while the vehicle is moving
  • Disable camera lockout – use the backup camera and/or added cargo/front/undercarriage camera at any speed for any length of time
  • ParkCam – uses parking sensors in front to automatically show SurroundView cameras when an object is detected nearby.
  • Automatic Drive Mode memory (TRX)
  • Auto Traction Kill – remembers the last state of traction control and will set it on start-up
  • Auto stop-start Disable – remembers the previous state of ESS system and will set it on start-up
  • Auto Tow Mode – remembers the last state of Tow mode and will set it on start-up
  • TurnCAM – can turn on backup camera whenever turn signals are used
  • AmberDRL – live mode for amber DRL and marker lights even when headlights are on
  • 0-30 and 0-60 timers (non-TRX)
  • Cooldown mode – run engine fans when Ram is off, to aid in cooldown
  • Winch mode – raise engine idle to 2000 RPM while winching or jumping another vehicle
  • Line Lock: Can lock front brakes for an easy burnout
  • Rock Crawl: Can lock all four brakes by pressing steering wheel buttons to hold the vehicle still, especially helpful when off-road.
  • Button Mapping: Use cruise up, down and right buttons as quick-access to some of Tazer DT’s functions, when cruise control is off.
  • Read and clear check engine codes and light.
Perf menu:
TPMS menu:
Radio menu:
Lighting Menu
  • Disable Halo’s
Other menus
Live features
@Boosted you rock!! That was great info. Thank you sir! Seems justified to me.
Try typing all of that on your phone and when you’re done, tell me how it was because I wouldn’t ever attempt it to know…. 😂
Random question…. What menu contains the Turncam setting? I can’t find it and it drives me crazy. I need to turn it off.
Should be under live settings.
I just ordered, thank you.
QQ. What happens if you physically remove the Tazer without un-marrying it?
Thanks...
Thanks...
Thanks for the order.
Most of the normal features will continue to work but the live features won’t.
Can't wait for mine to arrive, the amber lights are calling my name. Lol.
where can we order for a 2022? I want the amber lights and the three lights to be on even without the headlights on. after you plug it in and make changes and unplug do all the changes stay on? I don't quite understand what "live" features are/mean. Not much information on their site either. Can someone send me more information? Thank you.
You gain about 15 hp with amber DRLs and the three extra lights being turned on.
If that's not enough to want to be live, I don't know what would be.
I saw a couple reports of folks having issues with the PCM after using the TaserDT. Have you seen any reports of that?
Not true. There’s a few individuals that assume the Tazer caused an issue with the PCM but the Tazer doesn’t do anything with the PCM. It works off the BCM and will not cause any issues.
If you scroll up to post 102 in this thread, I posted the full list of features.
Awesome. Thank you. Any issue running this on the vehicle with < 500 miles (IE Does it interfere with the launch control limitation)? Also, can this be easily plugged in without any tools to remove panels?
So, this module really couldn't be used against you if something major happened, correct? All I'd like is amber lights and auto-folding mirrors. Maybe a few other small adjustments, but I'm sticking with 35s, so no need to adjust for tires.
Also, what does Service say if the see it? Can it be easy unplugged and removed when you take the truck in for service? I'm assuming just the live features would cease to work until you plug it back in.
Well, technically if your turn signals quit working, the dealer could say the Tazer caused it to fail which is why it is recommended that you unmarry and remove from your truck before taking it in too the dealership. Depends on your dealer. I actually installed mine at the dealership when I picked it up and they thought it was the coolest thing ever…. lol
