Their lower pulley adds maybe 50 awhp and then doing the 3.09 upper (which is only a nats ass bit smaller than the stock upper) will add another 50 awhp.
I’m not sure what’s not “logical captain” for you since the data is really clear… just seems you haven’t actually researched it in the slightest. Here is the pulley cross reference…
As you can see, most folks just do the 2.85 upper which nets 100-110 awhp gain. That has the blower at 18.6k RPM. Blower RPM equals boost in this case since no other changes in hardware aside from pulley. Running an incognito lower (9%) with a 3.09 upper (the TRX-800 kit) will put you just under that since the ATI lower (10%) with that upper also makes 18.6k RPM.
Did they do a baseline dyno run on your truck stock with the front driveshaft still connected? I have nothing against Ripatuned but they did ignore my question about why on their dyno charts they did the stock run in a lower gear and whether that was a true AWD dyno or only turning the rear wheels. I’m personally weary of shops that over promise and prefer the ones that under promise.
Again, this motor has been around for 7 years. All of these packages have been done on the hellcats for literally that long. Want to learn something? Jump over on the hellcat forum and do some reading. All of the info is there with plenty of data and dyno sheets.
