- Joined
- Dec 21, 2021
- Messages
- 263
- Gallery
- 17
- Reaction score
- 145
- Location
- West Coast
- Current Ride
- Honda Insight
- Military
- Never Again Volunteer Yourself
Featured
- #41
Exactly, because you still have to do the job of filtering and if flow is all you want then just remove the filter like lots of drag cars do. There was a good post about this https://www.ram-trx.com/threads/15-trx-oil-filters-cut-compared.9481/ but it was regarding oil filter efficiency. We just don’t have anything like that with intake media.All of the dyno results for the TRX on an AWD dyno that I have seen are 560-580 awhp when SAE corrected on stock wheels. The ones that are higher they have disconnected the front drive shaft. That makes sense that the drivetrain loss is around 18-20%.
The Ripatuned 800 kit adds 100hp… looking at the mods it’s easy to see that this package consistently adds 100hp on the hellcat platform regardless of vehicle. So that would correlate to 640-660 awhp given the same drivetrain loss which also matches what I have heard for that kit realistically.
As far as flow numbers for intakes, I actually had a back and forth with AFE in one of those threads about their test method specifically because their differential pressure was lower than the actual flow rate for the motor. Therefore they had to extrapolate significantly.
The values each vendor is using is an artifact of their test setup. And while reducing restrictions at a given delta P will let you know if you are moving in the direction of goodness, it’s not a quantitative method for determining actual improvement in engine performance.
I am running the incognito and picked up about .2 sec in the 1/8th. I walk scat packs now. I definitely can feel a difference in power and have to turn traction control off or I will get unpredictable launches and it will slow me down a lot as the roll has to initiate before the power comes back on. Ripatuned claims 40-60 whp I believe which puts you with just a lower pulley for me in the high 700 hp with drivetrain loss. I make a bit higher boost than most because I have a negative density altitude. I am trying to see the value in the ripatuned 800. It feels more like a parts sell to me. I’m shopping btw
