The OE caliper wt just got updated - It's 26 lbs loaded with pads (wear is neglected) so there is a solid wt saving of 15 lbs per caliper which is very ssubstantial.
Our caliper pistons are made of stainless steel (machined from a bar stock) which has much lower heat conductivity than carbon steel (OE).
The fix piston caliper is more efficient and can provide instant pedal response (both inner & outer pads simultaneously) vs. OE floating piston which only acts on inner pad, while outer pads move only upon the bracket closure (there is a lagging).
