I've been using this for about 3 weeks now and haven't had any issues at all. Everything still works as it should. The camera is pointed down away from any of the built in electronics and I have the level 2 truck with all the options checked. No issues.
Does the unit not cover the area in front of the forward collision sensor?
You can see it here in this picture.
So I guess it sits underneath all of the OEM stuff, correct? Nothing inside that blocks the field of view of the sensors under there?
Correct. If you watch the video you'll see the comparison of it to the stock plastic cover that is there from factory. There's nothing additional inside that blocks anything that the stock plastic doesn't.
It's still showing in stock for me on amazon. Did you use the link above?
I did. For me, it's showing out of stock with Amazon as the shipper with Prime. You can still order from the manufacturer with a 3 week delivery window and a $21 shipping charge. I'll keep an eye on it and order when it's back at Amazon.
Looks like a great fit for the truck. My only concern would be it appears like it has some sort of generic image sensor and they just state CMOS sensor in their data.
I include daytime and night time video in my youtube video. The quality is the exact same as my nextbase 633w dash cam which was significantly more money. They are using the same processor and likely the same everything.
Yeah I did watch the video, thank you for including that footage.
I did. For me, it's showing out of stock with Amazon as the shipper with Prime. You can still order from the manufacturer with a 3 week delivery window.
I just went to there website and purchased it. I literally have a garmin on the way which I will be returning.
Thanks. I will subscribe on your UTube channel
Dash cams are pretty much a necessity nowadays and with how easy this one installs, the quality of it, and even the price, you should definitely check it out. It's made by a company called FitCamX and while I was searching for a good option for the TRX I came across this one and thought I'd give it a try. I was surprised to find that it has the internals of much more expensive dash cams with the quality to go with it. The install is insanely easy and it looks OEM. I have some day and night time video in the video below so if you're looking for a dash cam for your truck, check this out:
Big thumbs up. Great video. Did you do one for the radar detector?
If amazon isn't working, you can get it from their site here and save 6% with the following code:
Promo code: HHD6
Reactions: LDN
