New 2027 TRX at 100 miles not working and no ETA to fix
AI has been pretty helpful when diving into this issue..
TRX In-Tank Check Valve Behavior
While not a formal recall, TRX forums and Hellcat technicians document a specific fuel pump issue:
Long Crank / "Two-Turn" Cold Starts: The in-tank fuel pump module contains an internal one-way check valve designed to keep 58–60 psi of fuel pressure primed in the rails when the engine is off. In affected trucks, this valve develops an internal leak, allowing fuel to drain completely back down into the tank overnight. When attempting to start, the engine will crank for 4 to 6 seconds or fail the first attempt, then fire immediately on the second push
Good find.
Just an update, RAM reached out to me saying they do not know when the replacement fuel pump assembly will be shipped to the dealer for the fix, but I have been driving around with it still just have to prime the fuel pump every time, other than that love the truck.
You're a better man than me.....Hope the resolution comes sooner than later for you! How frustrating this must be.
I haven't picked it up yet but if it starts, that's an improvement. Even when priming the pump and not starting, it would crank multiple sessions. The pressure immediately dropped back to zero as soon as you stopped running the pump so it was a hard start for sure.
Pump is a different part number that doesn't show up in their system yet.
How the heck did they order it if its not in their system?
UPDATE
New pump going on Monday, RAM was great and expedited the part. Ill be happy to not have to prime my fuel pressure every time I get into the truck just to drive it. Other than this stupid hiccup, I love the truck! Ill post the invoice and part number when its done. Hopefully it starts up flawlessly LOL
UPDATE
Good luck!
UPDATE
We're glad to hear of this update!
Diamond
Ram Cares
Here is the invoice with part number on there
Update, truck went back to the dealer right after I got it back. Second fuel pump no good. They're waiting on another pump, again. Been 2 months and I have only been able to put on about 1k miles and most of that was to and from dealer visits. It's had a good run.
