New 2027 TRX at 100 miles not working and no ETA to fix
Going through the box to ensure every single fuse is fully seated.
Verifying levels for engine oil, transmission, transfer case, front/rear differentials, engine coolant, and the supercharger coolant loop.
Those are things you could check yourself, and easily, at no cost.
Will they install magnetic level plugs when checking the diffs and transfer case?
I agree. But a little of context. I live in Hawaii and having my friend/owner of the shop in Colorado, flatbed it to his shop and do all that for me and do a ton of stuff to it. I’m hiring a transportation broker to get it to me.
That's not true. Around me, if you buy from a local dealer you are entitled to loaner cars when your truck is in service and if they don't have any they will reimburse for a rental.
This is a dealer call not a Stellantis Policy. You are lucky. Around here some do some don't and that is with all of the Big 3. There are some versions of the Extended Service Agreement some call it incorrectly as an Extended Warranty as there is a legal difference that allow for a $35.00 dollar a day rental reimbursement.
Back in 2025, I was told Ram 1500 (including all sub-models) were the #1 LL vehicle in the US. Wonder if that’s still true?
Spending six figures on one…risky…and frustrating to have serious problems under 1000 miles. Gonna eventually cost Stellantis a TON!
My 2027 TRX is officially at the dealership. I know the owner, so I’ve been texting him directly about all the issues I’ve been having. They’re getting into it first thing tomorrow morning, and I’ll update everyone once I hear what they find.
I also asked them to check a few of the other things you guys mentioned, just to be safe.
While it’s there, I’m having power steps added too. Definitely should’ve optioned them when I ordered the truck. 😂
Figured I’d share what’s going on with my brand-new 2027 TRX and see if anyone else starts running into the same issue.
I first noticed something wasn’t right at around 50 miles. Every once in a while, the truck would crank way longer than it should before starting. A couple of times I actually had to give it some gas to get it to fire up.
It kept happening, so on September 8 I dropped it off at a Ram dealer here in Colorado. The truck had 985 miles on it at that point. They went through the electrical side of things and then tested the fuel pressure. They found that the system is losing fuel pressure and determined that the fuel pump/module is bad and needs to be replaced. The weird thing is that I’ve never had a check-engine light or any other warning lights. Now the bigger problem is actually getting a fuel pump. The truck has officially been put into VOR (Vehicle Off Road) status, and apparently there are no replacement fuel pumps available anywhere in the dealer network across the country.
The dealer has been working with Stellantis/Ram corporate trying to locate one. I also opened a case with Ram Customer Care and asked to have it escalated. Customer Care told me they put a request directly into the manufacturer for the part on September 11 and were told they should hear something back within five business days. As of September 15, there’s still no pump allocated to my truck, no ship date, and no real ETA.
Originally, they told me the most likely scenario was that I’d have the truck back in 2–4 weeks, but right now that seems like more of a guess since they still don’t know when they can actually get the part. Another strange part of this is that the service director told me their system seems to show the fuel pump being the same as other Ram 1500s. But he thinks there may actually be something different about the TRX pump and doesn’t feel comfortable putting another Ram 1500 pump in it unless they know for sure it’s correct. I even asked if they could pull a pump out of another new Ram they have on the lot and then replace that one whenever the new pump comes in. They weren’t willing to do that, which I understand, especially if there’s any question about whether the pumps are actually identical. So basically, my brand-new 2027 TRX is sitting at a dealership in Colorado, VOR, waiting for a fuel pump that Stellantis currently can’t give me an ETA on.
To be fair to the dealer, they’ve been good about it and seem to be doing what they can. The frustrating part is simply that the replacement part apparently doesn’t exist in the supply chain right now.
This is not good gentleman. I have a 27 ordered, but it’s scary to know the nightmare of dealing with the dealer or Ram. My radio issue was finally fixed after 4 years in my 22. It’s finally enjoyable to have peace not worrying when the screen will go dark. Ram really needs to get their act together. If it wasn’t for the forum and guys supporting each other we would all be in the dark. Thanks to all of you for your time informing each other. It’s not easy sharing these stressful events.
This is from the Terms and Conditions of the Warranty regarding what some call loaner vehicles. VERY Limited to just Puerto Rico:
4.5 ALTERNATE TRANSPORTATIONAccording to Rule 17.2 and Rule 19 of the Motor Vehicles Warranty Regulation issued by the Department of Consumer Affairs of Puerto Rico, provided that the repair of a new motor vehicle exceeds a period of more than five (5) calendar days, excluding Sundays, unless the vehicle is engaged in public transportation or commercial exploitation or that the delay in repair is due to a fortuitous case or act of god, the consumer may request a loaner of similar transmission to the one under repair. This obligation will last for three years or 36,000 miles on the odometer, whichever first occurs. See the above mentioned DACO regulation for more details
To provide some clarity regarding loaners, loaners are handled entirely at the dealership level and based on availability. If they do not have any to offer during your services, you can go the rental route. In this option, you will need to pay out of pocket up front, but you can apply for possible reimbursement at the conclusion of repairs.
Diamond
Ram Cares
Diamond
Ram Cares
The problem is they make sure they don't have any loaner vehicles and you all at corporate don't provide any either! Always putting it on the customer instead of taking some responsibility and really helping!
Update: Dropped off my 27 TRX due to failing to start properly just like OP, dealer kept it overnight and is looking at again more today. Very frustrating to say the least. Plus note, got oem power running boards installed at least while its there 😅
I made a thread about my failure issue last week. Just stumbled across this. 800 miles and I have a long crank no start, might start on the second crank issue as well. I had a limp mode and check engine light that only lasted one run cycle, went away and no stored codes for it. I also had a starter overheat timer period to wait before restart of 4 minutes. Mine is also at the dealer now and I'm assuming I'll be in the same boat here but I sure hope not.
On a 27 also?
Its obvious RAM is holding back all the new fuel pumps for assembly line trucks. Zero available for repairs. Betcha $100 they had a BUNCH that failed quality control and were rejected, now they are running short.
Reactions: Two
Update:
Picked my truck up today they couldn't find anything wrong with it, of course not. I get to the dealer early this am and the truck fired right up. But drove it around today to work and to dinner with my wife and same shit is happening. I videoed everything this time to show them what is going on since they couldn't mimick it. Its really frustrating at this point because back to the dealer it goes tomorrow. Such a inconvenience.
Here is the video of what the truck does
TRX Rough Start
Diamond
Ram Cares
The funny thing about this quote - is you actually think it contributed to the "issue" that plagues nearly EVERY CJDR service department. I had my $110k Grand Wagoneer in the shop (prior to buyback) for weeks at a time. Only once was I provided a loaner: a stripped down base model Wrangler!! ONLY after raising hell with Stellantis Executive Referrals team, did I get authorization to go rent a comparable (Yukon) and received a reimbursement check afterwards!
