Just to help you guys out, I bought one from you and installed it on my 2022. I started on the passenger side, I used the supplied sway bar bracket and centered it so I had plenty of metal around the holes I drilled. There are already some holes from the factory in the wrong place. I then moved to the drivers side and measured off of the passenger side to get the brackets even and then drilled my holes on that side. I attached the brackets with the supplied bolts and some lock nuts I got from the auto parts store. There is not much room to get them started but it can be done. Last, I leveled the sway bar and attached my end links. I used the recommended bolts and bushing inserts from this thread. I bought them at McMaster Carr. This was not a super easy job, but it was not that complicated either with the correct tools and hardware.
I have put about 500 miles on my setup and all the hardware is still tight!
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
www.mcmaster.com
