Group Buy #1: RB Performance Brakes 4-Piston BBK For 18" Wheels Q1 2024 (CLOSED)
Spiegler in Ohio is a custom brake line manufacture and also HEL performance. We use both in our race builds.
If logos are a holdup please make mine without a logo then.
Thanks for the leads but upon contacting we found none of them is a viable source, while we are still waiting from Goodridge who is one of the two major brake line builders we dealt with.
Being TRX has different configuration than standard 1500 and due to its low population and relatively new on the market, no brake line builder is interested in making them. We have a local shop who is specialized in fluid handling plus Crown Performance in Vista. I feel one of them is likely to be able to make the kit available with our involvement but just need more time which is what we anticipated and so expressed as the kit was released.
For those who you are waiting for the brake lines, we suggest go ahead and install your new brake kits, drive around and see if you still need an upgraded brake line.
Well my order says waiting fulfillment so I'm over it. You can move someone else into my spot and refund me please
Orders are shipping and expected to complete by the end of this week or early next week.
If you ever purchased a caliper brake kit, we hope you would appreciate how our brake kits are shipped - All components are pre-assembled and properly torqued like below. (Silver caliper)
Unlike others you even have to adjust the mounting heights with some loose wahsers. We spent extra time to save your time, uncertainties or surprises.
Anyone who have received the order are welcome to post an "open-box" review even before installation, we appreciate all feedback.
Wow those look great! Hopefully GB2 fills up fast so I can place the actual order for this.
Any news if Goodridge will be making a SS brake line kit?
Goodridge just replied saying they will be working on a quote.
All GB orders have been shipped as of yesterday. It takes 4 weeks to fill the order including the caliper color options.
Thanks to "Psifer" for organizing this GB and GB participants for your support and patience.
We hope you will find these kits are made so easy to install, but do drop us a line should you require any assistance.
Good lucks & enjoy your new brake kits and we look forward to continue serving your braking needs.
Received my kit and it looks great. Will likely install next weekend.
I hope that one of you that got the kits can do some testing even if it's a couple of runs.
Calipers come with XT910 compound brake pads which was voted by Trackhawk owners as the best pad for spirited and street driving, no squeaking, very low dust, linear modulation, delivering consistent brake torque under elevated temperature w/o fading.
Since you are the first member installing the caliper kit, your first impression on the caliper swap will be welcome and regarded.
Any recommendations on what brake fluid to run?
Got through some first drive impressions yesterday. All my sentiments are positive. For context, I got the front caliper kit, which includes the XT910 pads that Warren referenced, but reuses the OE rotors. I only have 16k miles on my rig, so I didn't want to replace the OE rotors unnecessarily.
Install: It took about 3 low stress hours to install, very casually, including removing all wheels, flushing the brake fluid on all 4 corners (with Motul RBF-600), etc.
Bedding: Instructions for bedding the pads are included and were fairly easy to do safely. 6-8 brakings from 35 to 25mph + 3-4 brakings from 55 to 40mph + 10-15 minutes cool down, which I did by coasting on the highway to pick my buddy up from the airport.
Actual usage: My main intent was to improve the brake feel, as I felt the OE brakes were not confidence inspiring at all. That goal was absolutely achieved with just the front caliper replacement. The pedal is significantly firmer and it's easier to modulate the brakes, which results in a better handling car, since I can have more precise control of the brakes when going into a turn (some context: I drive road courses like Watkins Glen, VIR, Summit Point in a 911 GT3 with AP Racing calipers, so I really, really like using my brakes to load up the front to turn in [not just to stop]). In highway driving, I felt more confident driving at higher speeds and when going onto ramps, I felt comfortable approaching with more speed than usual, knowing I could shed the speed before the turn began. Framed differently, if the truck had came this way, no one would be complaining about the brakes. Also, the balance of the car is still 100%, which I assume is a factor of the strategic piston area that this setup was designed to have. Conversely, in my JL Wrangler (with a Magnuson Supercharger), I have 6 piston Baer front calipers w/ OE rear calipers, and while they do their job, there is absolutely a ton more front brake bias than the car came with. I've altered my driving habits to adapt to that, so no big deal, but it's nice having the OE balance with this RacingBrake kit, especially considering I do intend to tow and use this truck for other utility. Value wise, the front caliper upgrade feels like a no brainer to me. Framed differently, if it was offered as a factory option for the MSRP of this upgrade, I think nearly everyone would tick the box.
I don't really intend to do any 70 to 0 stops or equivalent, as that's simply not how I use this truck, but I'm glad to help answer any subjective questions if I can be helpful in that way.
Looks: They look great! The factory beadlock wheels cover up the bulk of the caliper, so it's more a subtle thing.
-Anu
PS: I installed a rear sway bar at the same time as these brakes, which made a very significant improvement in on-road handling. With the brakes + sway bar, it's like this car got some upgraded handling option that should have been offered from the factory.
Thank you to Warren and @Psifer for getting this GB going. I'm very happy to have taken part in it.
