Drive LED lights in headlights
Ravage
TRX Fan
SoMD
2021 TRX Flame Red
Military
U.S. Navy
Hello,
I have seen some trucks with the amber running lights above and below the headlights.
Can I do this on my truck, or is that taser device needed?
Thanks
Yes the Tazer gives you that function.
Hello,
Thanks
Tazer!
With latest firmware on Tazer DT you can also activate the marker lights in hood scoop and each corner along with the amber halos in the headlights .
Awesome! need to get one once they have the 2022 stuff figured out!
for the Tazer DT is it just plug in the SGW module or do i need install the bypass behind the entertainment center? i bought it but just havent installed it yet.
Does Tazer work on a 22?
I believe the setting is for DRL Location and then select turn signals (or vice versa). Make sure DRL are also enable in the Uconnect settings cause I've seen them sometimes get turned off.
It's on their website - not sure that it's '22 specific, the latest version is 18.1.0
thanks for the info
So what's the option for the DRL amber lights similar like the Raptors?
Is it set to DRL amber Low Beams always on?
Where can I get Firmware version 18.1.1 for a 2022? It’s not on the website?
