Everyone has read your thread of you trying to defend your numbers as true whp values until I posted your own shop saying they weren’t real.
But I appreciate this post because once again you show you completely don’t understand anything automotive. Hub dynos still have a significant portion of drivetrain losses from the torque converter efficiency to gearing to the rotational mass/inertia of all of the spinning components. Taking the tires off is only a part of “drivetrain loss.” The issue with why hub dynos can read wildly off is because changing one simple input parameter can greatly adjust the output value. Wheel mass and moment of inertia has to be manually input into the dyno (unlike environmental parameters that are typically automatically loaded via sensors) which means there is an opportunity for the user to easily manipulate the results in either direction.
Pretty much every single person on your thread called out your numbers as being exaggerated. Meaning that the dyno was not setup correctly and a correctly setup hub dyno will take into account ALL drivetrain losses.
You were quite literally the only person on your thread to lack the basic IQ to come to the same conclusion until I dropped in the convo I had with your own shop.
As I type this I realize you must be trolling this forum…no one can actually be as stupid as you.
