Drone mobile support is utterly useless. They just comment you back to your installer. That said, the GPS takes a few hours to initialize with the LTE system after install, I’ve installed 4 of these and the first few locations are always wrong, frozen etc. It self resolves once it gets its act together.
That said if you are using the premium trial, perhaps the functionality is less than you are looking for. for their more expensive plan, plus or ultimate has bread-crumbing where it shows your route at 2min or 30sec intervals respectively. Thought I’d mention that incase it was overlooked.
If the fob says fail, 10/10 that whatever you’re trying to do isn’t enabled or module not installed. Shock sensor for instance, or otherwise optional module not installed. Aux mode on the fob will be set (if installed this way) to manipulate whatever is installed on those inputs, if nothing, nothing will happen. Again optional modules or tie ins to other systems/aftermarket accessories.
@marksouth i carry both my T13 remote and the ram remote. Use the T13 remote for everything, I think in theory you can just carry the t13 remote, as the compustar system clones the fob to use with its remote start system, never tried it personally, don’t mind having both.
