BrawlerFab TRX build
Any desire of getting the blower ported? Or porting it yourself?
Probably not. I may look into swapping over to a Redeye.
Maybe he has some e85 availability where he’s located?
Believe it or not, there are only a few stations in all of WA state that sell E85 and one of them is 15 minutes from me. I may eventually play with a different set of injectors and tunes.
Full send. Lots of extra power on the table for you.
What’s a used redeye blower go for?
I feel like unless you go e85 there’s not much gain from swapping blowers. The stock hellcat blower is a pretty good factory unit.
Just go all out and grab a new gen 5 whipple. That would be sick.
If I go E85, I would go with a Redeye simply because it is way cheaper than a Whipple and perform better than what I currently have. :cool:
I did a quick Google search for a redeye blower .. not sure what currently prices are but in 2019 used units looked to have asking prices of 6-7k. That’s whipple territory
I've seen them in the 4500 range..... guess I should have jumped on it.
You’re probably right. What I saw was a few years old. There just wasn’t a lot of results that popped up for the quick search I did.
I had them installed by the dealership during PDI so they were on the truck when I took delivery of it with no level. Slight rub when turning full lock and hitting a bump on the inner liner behind the tire. Nothing a heat gun can’t cure.
Paid $4700 with Mopar sensors and gorilla lug nuts, was asking $3800 without lug nuts but I will let them go for $3500. They have less than 3000 miles on them.
Did you end up selling this set Bill?
Check this out!
I should have started this from day 1 to properly document my build but I guess it’s better late than never. Here’s how it currently sits on 37” Nitto Recon Grapplers and a Rogue Offroad level kit with a lot more to come. 😎
Hey dude, what is that light bar holding those lights?. Thanks for any info you can give me.
Those look awesome.
What’s the weight?
They are heavier than I want (32 lbs) but best I could do in short notice. I’ll eventually get some Weld Racing beadlocks.
