BrawlerFab TRX build
Hey dude, what is that light bar holding those lights?. Thanks for any info you can give me.
Your timing is impeccable…. lol
That looks great! I need to get off my ass and order the lights for the light bar you sent me. There are so damn many of them I can't make up my mind.
I’ll help you make up your mind. There’s only one choice: Rigid Industries 6” 360 light. it’s what I have and well worth the money! The only choice you’ll have to make is the background color.
I also welded my light brackets to the light bar and powder coated the whole thing, looks great and lights can’t be stole.
What is the largest diameter of round light that would fit on your light bar? Would a 7 inch light work if you had four of them?
You can run up to a 9” light on the Pre-Runner light mount.
First test n tune with the TRX. It was a cold (46 deg) night and a lot of moisture in the air so they ended up shutting down early as the track started getting wet but we were able to at least get a few passes in and some valuable data for the next time. This was the first TnT at this track for the year and the track surface was horrible. The traction was worse than running on a virgin street. The Nitto Recon Grapplers was pulling rubber off the track and probably pissing off the guys on slicks....lol
4/15/2022 4PM-7PM
Bremerton Raceways 1/8 mile track (I was disappointed as it used to be a 1/4 track until a couple of years ago)
46 degrees, overcast, 45' elevation with a -240ft DA
Truck setup:
Full weight with nothing removed,1/2 tank of 92 octane pump gas with 2oz of Boostane added to bump up to 94 octane, Sport mode, auto shift and 37x12.50R20 Nitto Recon Grapplers aired to 50psi.
1st pass: 8.400 @ 91.11mph with a 2.208 60'
1500rpm launch - smoked the tires all the way through 1st, 2nd and 3rd gear before I let off and got back on it.
2nd pass: 9.187 @ 73.98mph with a 2.014 60'
1000rpm launch - spun the tires and wheel hopped so violently that the PCM pulled a bunch of timing and made only 2# of boost (explains the time and mph)
3rd pass: no time (8.55 @ 88.90mph with a 2.08s 60' according to Dragy)
Off idle launch - spun the tires and wheel hopped not nearly as bad as the previous run (no timing pulled, 15# boost made)
4th and final run (track closed early due to moisture in the air) 7.622 @ 94.47mph with a 1.924 60'
Off idle and rolled into the throttle - no tire spin but obviously a very soft launch. Pulled hard all the way down the track and through the traps.
The truck has a ton of potential and I cant wait to get the 32" Nitto Drag radials on it for our first trip to Pacific Raceways and a fully prepped 1/4 track. Based on the numbers from this day, I can see 1.45-1.5 60', 7.0 1/8 and high 10's in the 1/4 as the goal.
Thank you to Nitto Tire, Ripatuned, HP Tuners, Vicious Motorsports LLC, Ultimate9 - USA, Rugged Radios and BrawlerFab for supporting this build.
Photos courtesy of #BrawlerPhotgraphy and Whitney Davis
4/15/2022 4PM-7PM
Truck setup:
View attachment 39736View attachment 39737View attachment 39738View attachment 39739View attachment 39740View attachment 39741
Curious bro...what wheel and tire setup are you currently running in these pics? Love the look of them. Leveled or lifted? Eager to hear your response. Thanks!
Leveled with just the lower perch from the rogue offroad kit and 37x12.50r20 Nitto Recon Grapplers mounted on 20x9 Weld Racing Ledge 6 wheels with zero offset.
$3800 for a lifetime round trip ticket to go whenever you mash on the go pedal. 😎
$3800 total got you that power increase?!
THAT LOOKS SINISTER. All business there. Question how did they perform over the stocks? what are their height?
I haven't run them yet. Just put them on the truck and drove it from the shop to the house and back....lol
Waiting for the weather to cooperate so I can take it to the track. :cool:
