Featured
- #321
I’m fine with you labeling me with a cool truck2021 final peasant edition+
2021 final peasant edition+![]()
Damn your tire pressure is crazy highHere are some pictures I took today. @OnTheReel can give you pics of the customized cards.
see what I posed previously about even contact patch lol. also to add to that my wheels are 20x10’sDamn your tire pressure is crazy high
how are you making out?Will do, tomorrow mornings first project
Ran into a snag. I only have alfa for android phone and tablet. Cannot access or edit the files saved on newer versions of android.how are you making out?
did mine today. My scratches were not too bad but noticeable when the sun hit it right. It would have been much easier to do on a table like yours but still doable while on the truck. I just removed the trim.So I did the scratch removal on the lens. Came out better than expected. Tiny hairline spots but you have to angle it in the light just right to see it. There's no way you'll see it in the truck.
Before:
During:
After:
i have the windows version of Alfa alsoRan into a snag. I only have alfa for android phone and tablet. Cannot access or edit the files saved on newer versions of android.
Just got a response from Alexey so I'm going to try something on my Amazon Fire tablet to see if it'll work.
@OnTheReel got it to work with a windows version of alfa, which I would have to buy it again. And I don't have anything windows that's portable to the truck..
You need to use a text editor app to edit the backup file on android version, but it can definitely be done.Ran into a snag. I only have alfa for android phone and tablet. Cannot access or edit the files saved on newer versions of android.
I can't even access it. Only says this:You need to use a text editor app to edit the backup file on android version, but it can definitely be done.
yea I have 325/60/20 and that is what looks to give me even contact patch. Would rather a little high vs. rounding off the edges of the tires.
Yes it came up in the evic as TRX Final Edition. . That was when you cycled the push buttonI believe so. They touted a special start up screen for the Final Edition
Jimmy’s harness goes to the oem cluster harness and then the 23 radio. I’m assuming the part that goes to the 23 radio is what sends the maps to the cluster.Anyone know what the other end of jimmy07’s harnes goes to? Is that c1 on the bcm? Blue connector?
Ok I was wondering thanksJimmy’s harness goes to the oem cluster harness and then the 23 radio. I’m assuming the part that goes to the 23 radio is what sends the maps to the cluster.
File changed successfully. new tile switch in and voice button works as indicated on the switch. Took it for a short spin, tile button does nothing so far. I'll keep checking it this weekend, we have a lot going on so I'm sure IF it does work, it'll be in the next day or 2.Ok, if you can try the same as above with the new switch, I guess we have all options on the table.
i’m sure that is what we all figured, but it is always good to rule out all optionsFile changed successfully. new tile switch in and voice button works as indicated on the switch. Took it for a short spin, tile button does nothing so far. I'll keep checking it this weekend, we have a lot going on so I'm sure IF it does work, it'll be in the next day or 2.
If it was gonna work it would have right away. When I discovered the setting you just changed (trying random shit in desperation) the changes took affect immediately. Sounds like yours did too if the tile button does nothing now. If you revert to the original backup I bet the tile button will do VR again just like the old switch.File changed successfully. new tile switch in and voice button works as indicated on the switch. Took it for a short spin, tile button does nothing so far. I'll keep checking it this weekend, we have a lot going on so I'm sure IF it does work, it'll be in the next day or 2.
