M&R light bar
And Shift&Grins reverse light kit.
Today I installed the passive entry on the rear doors. There’s a thread that cover all the steps.
Thanks to @Jimmy07 he sells all the wires and connections that makes the installation much easier!
How long did it take total
Installed fumoto drain valves on the engine oil cooler and oil pan while changing the oil
View attachment 86911View attachment 86912
I've always heard of these but never used them. I am assuming you have used these before? Any issues at all? Does that clip hold the latch well? Any issues in cold winters? Sorry for all the questions but I am leaning to buying a set of these.
I’ve run these on my Duramaxes and BMW diesels for 10+ years. Black clip holds the ball valve in place and never had any issues with salt corrosion here in Iowa where everything rusts…
It’s so nice to put a chunk of hose on and direct the oil right to the drain pan… also nice never to have to replace washers or worry about stripped plugs.
Jay
Yes been using them awhile on my vehicles and alot of our heavy machinery,, dirt equipment, cranes, and tugboats have them
The black clip just holds the valve from moving backwards. The valve is spring loaded and has to be push back before you can move the valve to the open position. Cant comment on cold as I'm in Texas.
I would definitely get some as they make oil changes way easier and less messy. And the oil cooler is alot less likely to get broke or cracked. And as stated above, less worry about a stripped oil pan or leaky washer
