Oh, I definitely agree. I can just understand the appeal of using the Aux circuits, especially if you're not experienced with splicing and soldering wires.
What would be really nice, is if someone would offer a wiring kit, which consisted of an inline "tapping harness" that would plug into the stock headlight and fog light connectors, allow the factory wiring harness connectors to plug in to it, and switch included relays for low beam, high beam, marker, and fog lights. A provided power wire would connect to either a switched, or constant, power source (user's choice) to supply +12V to each relay, and a provided ground wire would ground each relay's coil. Then you'd have a plug-n-play solution that would give you 1-wire (fuse-protected) connections to any desired add-on lights, controlled by the factory lights. Ideally, you'd use Micro-2 fuse sockets to provide fuse compatibility with the rest of the truck.
And, with a simple change in wiring, any of the four relays could have their common power supplied by an Aux circuit, instead of a constant power source. Then the Aux switch becomes an "arming" switch - when on, the stock high beams turn on your mega-lumen light bars. When the Aux is off, you just get stock high beams.
Anybody want to run with this idea?
@Boosted?
@Shifts_And_Grins? Send me a sticker, and we'll call it even
