Tazer DT GROUP BUY
@RetroShop do you know if the sunroof shade can be controlled independently from the tilt button?
I don't think that has to do with the BCM settings.
It has been a year since I was in my DT (19 Ram 1500) that had the pano roof (sold it) - but I could have sworn that it had its own button to open / close the shade. I could run around with the shade open all the time if I wanted.
I may not understand what you are trying to do though......
I want to have tilt open (separate button you are correct) and only Crack the shade open an inch. Basically airflow (sucks heat out of the Rams headliner area) but avoid the sun.
ahhhh..........I gotcha.
I can talk to them, but I don't think that is possible.
@RetroShop thanks for setting this up! Just ordered.
You can set it in the truck (native dashboard) to turn off or on at start. Not sure about remote start, and I didn't see any temp rating change.
Correct but If you use the key fob to start the truck, it won't turn on the heated seat and heated steering wheel when the outdoor temp is above 40 degrees.
Ordered mine...1st accessory purchased for a truck that I ordered almost 7 months ago...AND DON'T HAVE LOL...I To bad Lego doesn't make a TRX, I could build it, put it on my dresser and set the TazerDT on it LMFAO!
Does this raise or delete the top speed limiter?
No it does not.
This modifies BCM related options, top speed would need a PCM programming tool (custom tune).
No it does not.
Ordered! Main reason for my purchase is setting the turn signals as DRL. Do you know if you can set the hood scoop lights as DRL too?
I had to do this after your post.....
Not a TRX, but my 3D printed truck business card holder on my desk at the shop
I dug into the wiring diagram for those the other day. They seem to be tied to the trailer parking lights. With that.....it won't be part of changing the DRL to turns, totally different circuit.
