Featured
- #421
Hello, just wondering if anyone has heard anything on when the ordering will open for the 2024 Trx. I’ve talked to my dealer and it doesn’t even show up on their system
Oh boy…? What possible scenario would cause it to be stuck in IQ? I feel like there is a dark cloud over this whole purchase…Seems to be stuck in
Seems to be stuck in IQ status cert test.
You can skip all of the reading in the post that @IdahoKTM linked. You can't order a 2024. It's dealer allocation only. The only way to get one now is find a dealer that will give you an incoming TRX (or find one on a lot).Hello, just wondering if anyone has heard anything on when the ordering will open for the 2024 Trx. I’ve talked to my dealer and it doesn’t even show up on their system
Thanks a lot for this. Was holding off to see if I can spec out a 24’. Thankfully there’s a dealer near me that has the exact spec I want only as a 23’ with 1000 miles. Might just have to take the L and look into that oneThe link goes straight to the post that says you can't order a 2024.
I'd snatch it up if I were you. The 2023's are substantially cheaper than the 2024's (with no known differences). Not to mention that you may or may not be able to eventually find a 2024 that suits your needs.Thanks a lot for this. Was holding off to see if I can spec out a 24’. Thankfully there’s a dealer near me that has the exact spec I want only as a 23’ with 1000 miles. Might just have to take the L and look into that one
You might be right. Well fingers crossed hopefully I can go and check it out it’s about a 4 hour drive to get thereI'd snatch it up if I were you. The 2023's are substantially cheaper than the 2024's (with no known differences). Not to mention that you may or may not be able to eventually find a 2024 that suits your needs.
If you can tell me the last 6 digits of the 2023 VIN you're looking at, I'll tell you if there are currently any 2024's that have the same specs.You might be right. Well fingers crossed hopefully I can go and check it out it’s about a 4 hour drive to get there
It was just a final cert test for door locks and key function and the like. Nothing serious. Operator error.Oh boy…? What possible scenario would cause it to be stuck in IQ? I feel like there is a dark cloud over this whole purchase…
this one is in fit and finish then will be certed then shipped to dealer or outside accessories70 more TRX Build Sheets found today. 1 more forum member with a truck starting production! Congratulations to @TRX427
This one is out of the system shipped to whereverFound 25 more TRX Window Stickers tonight. 1 more forum member with a truck on the way! Congratulations to @KenF
Yea dealer just called to tell me they sold itIf you can tell me the last 6 digits of the 2023 VIN you're looking at, I'll tell you if there are currently any 2024's that have the same specs.
Well, that one is one-of-a-kind. There have been no other trucks built with that exact configuration (2021 thru 2024, at least as of right now).Yea dealer just called to tell me they sold it
Last 6 digits at 505103
Y'all seriously rock on the updates!!this one is in fit and finish then will be certed then shipped to dealer or outside accessories
Hey @Viperjim would you know what IQ status means or why it might get "stuck" here? Or maybe its past this status now??Seems to be stuck in
IQ status is halo inspection and cert test which then gets put into ship mode and then to shipper to go to accessories upgrade or shipped if nothing added after factory bedliner, side steps, graphics, rollbar ,etc. as all of those are done outside source. Then ships back to the plant and then out on transport to vehicle origination number or dealership.Hey @Viperjim would you know what IQ status means or why it might get "stuck" here? Or maybe its past this status now??
Ok, all I had was the side steps, liner, hood decal, level 2 trim and beadlocks ...I mean it was fully loaded but only with OEM installed stuff...no roll bar this time. So ill assume its waiting to be shipped on transport or train...Im only 8 hrs away in WI so id think they would just load on carrier, but my rep says by rail first then carrier to southern WI... adding weeks to the process possibly.. Hey thanks a ton for the intel.... so much to learn here... ITs greatly appreciated sir!IQ status is halo inspection and cert test which then gets put into ship mode and then to shipper to go to accessories upgrade or shipped if nothing added after factory bedliner, side steps, graphics, rollbar ,etc. as all of those are done outside source. Then ships back to the plant and then out on transport to vehicle origination number or dealership.
Well beadlock rims installed at the plant and all accessories are done offsite by third party then shipped back to the yard for final shipping. To bad the don’t do like the viper plant where you could pick it up yourself there and treated to a box lunch and tour and all the glam and glitter. And 2000$ for destination fees when was 995 a couple years ago. But inflation you know.Ok, all I had was the side steps, liner, hood decal, level 2 trim and beadlocks ...I mean it was fully loaded but only with OEM installed stuff...no roll bar this time. So ill assume its waiting to be shipped on transport or train...Im only 8 hrs away in WI so id think they would just load on carrier, but my rep says by rail first then carrier to southern WI... adding weeks to the process possibly.. Hey thanks a ton for the intel.... so much to learn here... ITs greatly appreciated sir!
Thank you so much for all this info, extremely helpfully.Well, that one is one-of-a-kind. There have been no other trucks built with that exact configuration (2021 thru 2024, at least as of right now).
Ignoring the items you can add later (like hood/exterior graphics, bed utility group, running boards), and looking at the "bones" of what you wanted, you'll have a hard time finding that in a 2024 too.
There has only been 1 truck built for 2024 with the following parameters:
Bright White, Level 2, Carbon Fiber, Red Interior Accents, Pano Sunroof, Trailer Tow Group (no Trailer Reverse Steering), and Trailer Tow Mirrors. And that one went to Costa Rica, lol.
Edit: If you can live without the trailer tow mirrors, then here's a fairly similar one that was recently stickered and sold to the state of Virginia. Unfortunately, I don't know which dealership it's headed to.
And one to Ohio that's also fairly similar.
