Hi, thanks for the reply. Some good information you provided. However, as for applying the throttle quickly, there was no pussyfooting, I immediately mashed it to the floor, each and every time. It says right in the information centre to quickly apply throttle, so, I knew from the beginning that it was necessary.
I suspect that, as per White881 inferred, my set RPM needs to be lowered. It's at 2400 or 2500, and others seem to be less than 2k.
I rolled significantly during the first three launches. I don't recall rolling during the following launches, but that doesn't mean it didn't roll at all.
I have a feeling that, I'll have a successful launch when I reduce the rpm. I'll set it at 2,200 and go from there, lower it incrementally until it works.I'll be a little disappointed if I have to lower it less than to 2k.
