Oil Catch Can on my new 2023 Ram TRX
@FULLTHROTTLERICK dual billet technology catch can installed. It came out well and looks awesome… let’s see how much I can catch.
Do you have any whistle air when you hit the gas?
I'm a little paranoid since I put the billet catch can because the straight bracket didn't fit as I think it should and it can be removed so easily. I think some air is escaping when you press the gas pedal. I was thinking of buying those brackets like the OEM to fit well. Does anyone know where to find them?
No air leak or whistling on my end. The catch can hoses fit snug and can actually be a pain to get off. Double check your connections and use hose clamps if you’re worried about them coming off.
I need something like this
No whistle air that i can hear but those fittings you're referring to are not air tight. air can escape through the areas you depress to remove the fitting
I don’t believe those clips are any more secure then the hoses from billet. Maybe it’s because you get that satisfying click with those stock ones. Instead of using the connectors that billet gives you, which I used and don’t find an issue with them, connect the hose directly to the port and put a hose clamp on it.
I will call them tomorrow and see if they sell those to buy the one that is not clipping
If it's not clicking then you need to push from a different angle b/c ur not getting enough engagement.
[INSERT DEEPER INTO HOLE FOR SATISFYING SOUNDS "CLICK"]
Right!
There's no way I could pull the BilletTech hoses off the fittings by hand.
Reactions: DMR
Try like your are unscrewing and you will see. I removed the catch can completely today, clean it (there is something weird to me I that can) and then I cut a little hose because it was kinked a little. There are some mishimoto hoses pretty solid.
https://a.co/d/eFlGPM8
What are the fittings included in the ADD W1 package?
The two barbs on the catch can itself and two lengths of hose I believe. I may have had to get more hose. But I cut the factory end from the OEM hose and used them with the new hose. I also ordered the red clamps and a 90* mount from them and drilled into the cross bar and riveted the bracket to it. love the way it came out and easy to get to.
Ok so i have an update to report. The mighty mouse (MM) can I installed on my passenger side is finally producing oil. See pic attached (i drained the MM can into my BT can container) since the MM can does not unscrew.
Good news is it seems to be catching everything because i have not had a drop of oil on the drivers side BT can since installing the passenger side MM can. MM told me that there was no need for a catch can on the driver side with their setup, but I obviously did not take their word for it as I had been catching oil on the driver side for a little while before installing the MM can.
Moral of this story is apparently the MM can is far superior to the BT can as I was getting oil on the driver’s side can when running the BT can on the passenger side. There is a F ton more media in the MM can thats for sure. Will update this again after a few more clicks on the ODO to be sure.
Also side note: the oil itself appears far less diluted than the oil color on my BT can (usually tan/coffee w/milk colored)
Reactions: DMR
Can you share the link you used to buy the MM?
So MM is better than Billet Technology Catcha can?
I've owned 7 BT cans and they were solid; however, the MM can appears to be far superior insofar as the "catching" ability of the can. Probably 3-4x the media of the BT can is the main reason.
