Well, I did mine today.
Used the Quicksilver Extreme Grease I spoke of previously. Took about an hour. Nothing complicated, but certainly physically taxing doing it on the ground. I threw down a moving blanket and used a lot of care handling the driveshaft. Before removal, I added alignment marks on both yokes. Remember to set the parking brake so nothing moves on ya. Electric ratchet is a blessing to have. And since I didn’t get new bolts, I put some blue Loctite on the originals when re-installing.
The boot clamp can be re-used easily. Like
@rao26 said, use a flathead. Pry up on the band (red arrow) until it goes over the tab (yellow arrow) and comes free. Once it’s off, you can straighten up any bends in the clamp to prep it for re-install.
To re-install the clamp, feed a small flathead through the last hole on the brand and “grab” the big tab (yellow arrow again). You can then use the screwdriver to lever the band back over the tab without any special tools. Once it’s over the tab, the clamp may still be a bit loose. Use the correct crimper (or improvise something) to squeeze the area in the blue circle together to tension the clamp back up.
Tried that first, there were literally no splines exposed with the truck on the ground at ride height. Maybe lifting the back end up would expose them a little more, but I see no way you could do the job adequately. As a lazy person, I hoped it would be so easy but it isn’t.
