Looking at replacing wheels but keeping tires
SevenMileTRX
Johns Creek/Milton/Suwanee
TRX 2022
Range Rover Sport PHEV
Hi guys,
I got the stock black wheels on my TRX that I ordered...hoping it is built soon...
In the mean time, I was thinking about purchasing new Fuel Reaction Wheels for the truck, but want to keep the existing tires. What size wheel/offset/bolt-pattern would I use with the TRX?
The stock size 18x9 +19mm offset. CatchMeOffroad has 18x9 zero offset. so either will fit. But you need to check the fitment before ordering, just to be sure whatever rim you select fits.
Brakes are really tight on stock rims. They don't vent well under aggressive use and you cant even put caliper covers on them without 20" rims. Plus stock brakes are only 2 piston/1piston setup.
To upgrade the brakes in any way you will need a 20" rim.
The stock tires are the best speed rated tires you can get for TRX but very limited in sizes.
Just a few things we have worked thru over the months having truck already.
Hi guys,
Fuel Shok 18x9 -12 offset with stock tires:
However I was just looking at the Fuel site and they don't show the Reaction in an 18.
