I got the kit...and despite the negative posts on it...it is pretty good so far....infancy stages of mounting it..more to follow...
1. Those of you that have it, what fuse location did you use for the pressure switch?
2. Where did you put the auxiliary connection point? (I.E. the air tank quick disconnect to use the system as an air compressor.)
Thanks in advance...
