You want the rings to seat properly, which requires the appropriate temps and pressures. If you don’t do it properly, the cylinders will glaze. And once that has happened, they are almost impossible to correct. It will cause extra heat, a reduction in power, and likely a shortened lifespan. To note, this is more likely to happen at low power settings/idling. But You also don’t want it to get too hot or the heat will cause the rings to become brittle and fail. And the friction of the rings on new cylinder walls will cause additional heat. So basically you are trying to balance all of that until the cylinders and rings are fully broken in. The break-in is usually in the first 10 or so hours. This corresponds well with the first 500 miles. I can’t speak for the transmission or differentials.
