Ok im undersatnding the load concept now. Agreed 25-30psi on the low would be good but what should my high side be at that ambient? I was speculating it should be around 100 based on the chart i uploaded but that's just a layman's guess. Is my high side pressure of 75-80psi within acceptable range for a 55-57deg ambient and no load on the system? Are you still thinking i may be a bit low on refrigerant?
I'm going to check AC pressures again on the hottest day of this week, after my truck gets to operating temp, hood closed, 2ndary condenser fan off, heat all the way up, etc., and see what they pressures look like when I flip it back to max AC and report back. Should i block my engine fan too? I've cut a piece of yoga mat for that purpose.
