Featured
- #121
Yea i've read that humidity thing as well which is why i was thinking that it would kick on to keep humidity in check and, in turn, keep IC temps reasonably cool but i guess I was either wrong or the humidity never rose to the level of needing to kick the compressor on (windows never fogged). Either way, the ambient highs are in the 40s the next 2 days so I'll have to retest this theory when i get home. It sounds like a reasonable theory so i hope it's correct!!!If you set your ac lower than ambient temps it should work fine. Just because the fan is blowing doesn’t mean the compressor is running. Once the cabin gets below your set temp (70-71° in your case) it’s just circulating air. If you want the chiller to work then you have to make the truck think you need ac even if you don’t. From what I understand there is a humidity sensor in the cabin and even in the winter when you don’t need ac it will kick the compressor on to lower humidity to keep windows from fogging up… think I read that somewhere or may of just made that shit up haha. So when you put it in chiller only mode and the cabin stops getting conditioned air the humidity rises and in turn kicks the compressor on.
If it is, what are we supposed to do in the winter when ambients are 40 or less? Just let IC/IATs be high? I remember reading something in the manual about warming the cabin and then kicking the AC on to trick it to turning on temporarily. Doing that over and over again on a long trip sounds pretty redic IMO.
